HELP! 2008 Prius stopped running AFTER replacing 12v/auxillary battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paisley's Prius, May 15, 2023.
  1. Paisley's Prius
    Paisley's Prius New Member
    Last week I had the 12v/auxillary battery changed, and everything has gone to hell since.
    Background - I bought my Prius used, just couple years ago. No probs until recently. Car periodically, then constantly, not starting. Sometimes the dashboard lights & such would light up as normal, except the "ready" light. Other times lights would be dim, or not working at all. Could always get it to start with jump box, but after several months of having to use nearly every time I drove it, I decided to replace the 12v battery. The guy at the auto parts store put it in, not a mechanic (yes, I know this not the best idea).
    After the new (and tested) 12v battery was installed, the car still would not start. After "tinkering" around with it for a bit, he discovered that my "fusable link" was broken and needed to be replaced. We were able to rig it (first with mini screwdriver held in place by another guy at auto parts store, then with aluminum foil and a penny) and the car finally showed "ready", BUT ...
    My smart was not registering whatsoever. I had to put the key in the ignition to start. Would not unlock doors, either. AND there were nearly every light stayed lit up on the dashboard, including "red triangle of death" AND two warning lights came on the touchscreen: red battery & car shape with !.
    After much debate and discussion about what might be going on, I decided to try drive it up the road just to see what would happen. I made it about 2 blocks & the car died. I was able to restart once, and actually put the car in drive and move it a bit, until it died again. Had to have it towed back to the auto parts store.
    I ordered the part they said I needed (fusable link box - I that's what it was called); got a few days later; had friend replace/install it (very easy). And it's STILL not starting.
    I have considered the possibility that the smart key may have something to do with it, but no idea how to find out or reprogram it. Also have checked fuses and approximately half of the once under the steering column are reading bad, but we pulled a little couple out & they appear to fine.
    I realize now that I should have taken it to the dealer, but I was trying to save $. I now have about $350 invested & the car is in worse shape then when I started. So any tips, suggestions or even guesses would be appreciated. Thanks!
  2. JC91006
    JC91006 Senior Member
    16,768
    8,565
    You had all these repairs done at the parts store? Where they don't repair but sell parts.....I think they only provide this service to women, any guy trying to do that, they would probably get shown the door.
    Anyways, I would first check if you have gas in the car.
  3. SFO
    SFO Senior Member
    5,302
    4,248
    Northern California
    Welcome to PriusChat!!
    Generally speaking, when you have warning lights being displayed on the dash, there with be obd2 codes stored in the computers. I find it odd that the parts jockeys had no interest in suggesting that it was possible to scan for those stored codes by using their OBD2 scanner.
    FYI : you're moderated until you've posted 5 times.
  4. Paisley's Prius
    Yes, there's gas in it. I can't speak as to why or why not the guys at the auto parts store tried to help me.
  5. Paisley's Prius
    What does that mean? "Moderated"?
  6. JC91006
    16,768
    8,565
    It seems very odd your car will start and go a short distance and then stop. Like if it ran out of fuel.
    Since you are certain there is gas in the car, then your next step is to make sure all the fuses are good.
  7. cyberpriusII
    1,155
    1,775
    Mars Hotel
    Next step is to have codes pulled. May not help, but wwon't hurt
    SFO likes this.
  8. dolj
    dolj Senior Member
    8,445
    4,290
    Wellington, New Zealand
    When posts are moderated it means messages go into a queue to be reviewed by a moderator to make sure it has not been posted by an internet robot. Until the posts are reviewed, they will not be visible to the wider forum community.
    Once you have 5 or more posts your posts are no longer moderated and, also, you will be able to post links in your posts.
  9. ChapmanF
    18,180
    During that moderation period, you might see a bunch of us asking you questions, and you answer the questions, and somebody else asks you the same questions, and you wonder why we keep asking things you've answered, and we wonder why you haven't answered yet, and then the moderator gets around to approving your posts and we see all your answers the next day or whenever.
    Sometimes when we say "FYI : you're moderated until you've posted 5 times" it's addressed to you, but it's as much a reminder to the rest of us to remember "oh, yeah, that happens."
  10. Paisley's Prius
    Thanks for the explanation!
