battery issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Zaza 13, May 17, 2023.
  1. Zaza 13
    Zaza 13 Junior Member
    74
    Israel
    can someone tell me if this temperature on nickel battery is high?
  2. Zaza 13
    74
    Israel
    car was standing on sunny place close to 4 hours, temperature outside is 35 cels. its impossible to drive the car in EV mode at all and there is warning
    scheduled : maintenance required for hybrid cooling system. but i checked and battery fan works
  3. Bill Norton
    Bill Norton Senior Member
    2,138
    732
    MONW, Ks.
    35C is 95F, so not too uncommon here in the US.
    Of course who knows what the temp was in the cabin of the car or the battery pack.
    (can't interpret you attachment. but it appears block 13# is a problem. That may be what's going on...)
    Yes, it's good to clean the battery cooling fan and ducts. But as always, it's just one of the many maintenance items toyota skips in the manual. There is a screen cover for the fan inlet if you carry your furry friends in the back much.
    You might consider a sun shade for the windshield and 'vent-visors' for the windows that allow the windows to be open a bit.
    This would allow the cabin to be closer to the ambient outside temps.
    I'm tempted to paint the roof of my dark gray Prius with that white 'Plasit Dip' stuff, at least for the summer to see how it goes. It can be blasted off at the car wash if you don't like it.
    A black car is a solar heated oven in the summer.:(
    edit: And Ceramic Window tint is amazing technology! It keeps the heat from coming through the windows so much better than just dark tint.
    #3 Bill Norton, May 17, 2023
    Zaza 13 likes this.
  4. Zaza 13
    74
    Israel
    this morning there was no any warning shceduled, my car is white but it has glass roof, car gets too hot during hot days, anyway if block# 13 goes to die i dont care because i have warrenty from dealer. thank u.
    Bill Norton likes this.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,026
    1,956
    NJ-USA
    I would check the inverter cooling system underhood- is the coolant level full, does the electric pump circulate coolant, etc.
    I think this message might be triggered by high temperature in the hybrid electronics (inverter - converter assembly).
    Zaza 13 and Bill Norton like this.
  6. Zaza 13
    74
    Israel
    inverter cooling fluid is ok, I think it happens only when it's too hot outside, yesterday was 37 cels. today it's 25 cels. and everything is fine, pay attention on midle block temperature, it was too high yestarday.
