2008 Prius MPG dropping like a rock after new 12v battery and coolant pump change
Discussion in 'Gen 2 Prius Fuel Economy' started by Jon Good, Feb 28, 2023.
  1. Jon Good
    Jon Good New Member
    Seattle
    Hey guys- I have a frustrating mystery. I recently changed my inverter coolant pump and my MPG dropped slightly from 40 to 38.. and then two weeks ago I had a bad battery and bought a new one from O’Reillys and now the mileage is going down every day and it is currently around 28 mpg. I hooked up the ODB scanner and looked at the hybrid battery with the free version of Dr. Prius, seems to be working fine.. I also put in a new air filter.
    What do you think might be going on??
    Much thanks for any responses.
  2. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    hmm. check your tire pressure. Also check and make sure you seated the new air filter correctly. Have you cleaned your throttle body or intake manifold? How many miles on her? If you are 125K or more and original..it is time.
  3. bisco
    51,553
    I think when you put in a new battery, the computers have to relearn everything.
    Track a couple tanks and let us know the actual mpg’s
    AzWxGuy and ColoradoCrow like this.
  4. Jon Good
    Jon Good New Member
    Seattle
    I think that’s what’s happening but it has taken MULTIPLE tanks of gas, like you said, as it’s returning to 40mpg ish. I ran it on the freeway a few times at 60, resetting the dash counter and then it started creeping upwards again. thanks for the many responses I appreciate it!
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    lol...the 12 volt battery has little to do with mpgs.
  6. Jon Good
    Jon Good New Member
    Seattle
    Yeah I’m not sure what’s going on now because the mileage creeped up a little bit when I took it on the freeway it goes all the way up to like 47 mpg and then Intown drops like a rock down till like 30.. ugh.
    But all this started when I changed the inverter coolant pump and battery. Before I was getting a rock solid 40 mpg all the time.
  7. dolj
    dolj Senior Member
    8,349
    4,257
    Wellington, New Zealand
    So which MPG meter are you specifically using?
    If it is the Average dispalyed on the Consumption screen (which is a lifetime since last reset), then the is a high chance that this was reset when you changed the battery.
    Depending on if you have ever pressed the "Reset" button on that screen then the average you saw before the battery change could be the average over many thousands of miles.
    With the average now reset, the average will be since the reset.
    The best way to know what is the true MPG is to calculate the true MPG by dividing the mile run on the cuurent tank by the numser of gallons you added the tank. Record the numbers in a biook (or better still create an account on fuelly.com) so you have a running record. When you fill up reset the Trip A and the average on the consumption screen. do the recording all over again at the next fill up. For this to work, you need to fill up completely, not partial fill ups.
    srellim234 and Jon Good like this.
  8. Jon Good
    Jon Good New Member
    Seattle
    Thanks for the answer I’ll try that and report back
  9. edthefox5
    10,096
    4,833
    Clearwater, Florida
    You never stated the miles on the car or how long you have owned it?
    You need a new hybrid battery based on what your saying. if you just bought it you def need a new hybrid battery.
    Needs new hybrid battery is probably #1 reason people sell there G2.
  10. Jon Good
    Jon Good New Member
    Seattle
    .. well here’s the conclusion to the story. Consistent 37 mpg after I did all that work dropping from around 40. Stay that way for a few months and then I went on a big road trip 300+ miles and it went back up to 40 and now it’s at 41.7 and has stayed there for months. Go figure.
    Linda Chan likes this.
  11. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Yup your in Stage 1 hybrid battery failure. A prolong charger can prop it up and get you another year and forced charging can help but its going to need to come out and be investigated before it leaves you stranded.
    A failed hybrid battery on a G2 is the number #1 post on this site. very common its just the age of that car. 15 years is a awesome run on any battery.
    Forced battery charging or power braking is very easy.
    When your in gear and stopped put your left foot on the brake and then gently press the gas till you see the charging bars on the mfd start to route power to the battery from the engine. Not necessary to floor it just press the gas pedal down enough to start the engine and get the bars moving.
    Practice with no one in front of you for a while to get confident at that. I did that for months at every traffic light before buying a Prolong..
    It works it will add blue bars to the battery. Or at least get you out of purple bars.
    Here's a link to the Search Forums list with the search word "Hybrid Battery Failing". Se how other people dealt with this:
    Good Luck!
    https://priuschat.com/search/429441022/?q=hybrid+battery+failing&t=post&o=relevance
  12. Jon Good
    Jon Good New Member
    Seattle
    That’s not what’s going on.
  13. edthefox5
    10,096
    4,833
    Clearwater, Florida
  14. Jon Good
    Jon Good New Member
    Seattle
    The point of this for forum is to help people and when you’re purposely peddling misinformation to sell stuff to working class people struggling with car repairs -that’s a real crummy thing to do.
  15. edthefox5
    10,096
    4,833
    Clearwater, Florida
  16. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    In town driving and short distance trips often result in lower MPGs, and disconnecting or replacing the 12v will cause the computers/ECUs to reset the learned fuel mapping/curves, which then reset to the factory default settings. Generally a good idea to clean the MAF sensor after any 12v work, unless already clean. Then use a toothbrush dipped in vodka or rubbing alcohol to clean the butterfly valve and throttle bore.
  17. Jon Good
    Jon Good New Member
    Seattle
    I see, thanks
  18. Ozzbo
    Ozzbo New Member
    29
    Austin
    How's your mpg now?
  19. Jon Good
    Jon Good New Member
    Seattle
    Between 42.3 and 42.5mpg
    Ozzbo likes this.
  20. Jon Good
    Jon Good New Member
    Seattle
    Honestly the mpg was bad for a few months until I wanna know 300 mile road trip..
    Ozzbo likes this.
