Prius Plug In gas engine cuts off after 5 seconds
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by William Lower, May 19, 2023.
  1. William Lower
    William Lower Junior Member
    Dixon, California
    2013 Prius v wagon
    Our 2013 Plug In had the "Check hybrid system stop the vehicle in a safe place" come on, as well as the "triangle of death" warning and other lights. Wife pulled it over. Had to have car towed to my driveway. I plugged it in and charged up the battery. Did a reset of the hybrid system using the paper clip method where the scanguage plugs in. Scanguage showed a 3190P - loss of power code at first, but now shows nothing. The ABS light and brake lights now stay on. I can start the car in electric mode and get it in gear, and move it up and down the driveway a little bit. I'm afraid to take it out of the driveway - don't want to pay for another tow. When I put the car in Eco mode or Power mode, the engine comes on but then dies after about 5 seconds. Anybody have any ideas on what the problem could be? I'm planning on having it towed to a hybrid meachanic specialist soon if I can't fix it myself.
  2. ChapmanF
    19,050
    The engine doesn't work. The 5 seconds before it "dies" are the 5 seconds the car is trying to start it, then giving up. The P3190 is consistent with that.
    The big 3 first things on the list to check when a gasoline engine doesn't work: fuel/air mixture, spark, compression.
  3. William Lower
    Dixon, California
    2013 Prius v wagon
    Hi. No, the engine actually runs well for 3 seconds, then sputters, and then dies by about 6-7 seconds.
    Tombukt2 likes this.
  4. BiomedO1
    4,636
    2,434
    Left Coast
    Sorry Bill, that's actually the electric motors in the transmission spinning the motor.
    I've bought and sold several Lexus RX4xxh that had a broken timing belt, that did that. Chapman is correct, The engine isn't actually firing.
    I even got lucky with one of them, no bent valves....:D
    Check your spark plugs and coolant levels. If you didn't lose power when the dash board lit up; you'll need to hook-up a scan tool to see what other codes are popping up.
    #4 BiomedO1, May 19, 2023
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Can someone with a Tesla chime in please, I got some free time to waste on here with extra curricular reading to do
  6. ChapmanF
    19,050
    Yup, at first it is just being twirled by the electric motor with no fuel or ignition, then the sputtering starts when the car begins the fuel injection and spark and hopes it will pick up and run, and when it has only succeeded in sputtering by 6 or 7 seconds, the attempt is given up.
  7. Mendel Leisk
    42,369
    Repeated engine “starts” like this will eventually run the hybrid battery dangerously low.
  8. William Lower
    Dixon, California
    2013 Prius v wagon
    Its a plug in prius. I'm keeping it charged up. When it first broke down the battery icon on the dash showed the battery all the way down. I think the car stopped driving when the battery was drained. I could probably drive it out of the driveway but its a first generation plug in - it will only go about 10 miles at best.
  9. Mendel Leisk
    42,369
    More important to find out what's wrong and rectify it, then to make the car move.
  10. bisco
    52,888
    how many miles on her?
    could you be out of gas?
  11. William Lower
    Dixon, California
    2013 Prius v wagon
    The fuel gauge has 3-4 bars on it. Its never been that inaccurate that we know of. When you switch off electric mode it sounds like the engine briefly runs, but the guys above don't think the engine runs - that its the electric motor turning the engine. It sure sounds like the engine runs to me, but now I'm doubting it. The engine oil was changed a few hours prior, but I checked and its not over-filled. I've checked a few fuses. May check some more. I'm thinking of eschewing the dealerships and towing it to a hybrid specialist.
  12. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    It sounds like it is running mostly because when a Prius transaxle starts its engine, it does so at around 1100RPM, much more than the 350 or so than a traditional car starter can spin its engine.
    Hit it with some starting fluid or an unlit propane torch in the intake, see if it'll run on that fuel source instead of the gasoline that may or may not be going in.
  13. bisco
    52,888
    i'd fill the tank to be sure. aafter that, it's plugs, coils, fuel pump, wiring, ecu, it gets complicated
  14. William Lower
    Dixon, California
    2013 Prius v wagon
    The car has 160,000 miles on it. Wife and I are pretty sure the engine is firing up. You can smell exhaust fumes. Scan guage showed initial rpm at 1400. ABS, brake, and slip indicator lights are staying on for some reason. I'm suspecting maybe a fuel pump. I don't think gas is being properly pumped to the engine.
  15. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    First thing to do is put gas in it. Don't trust the meter.
  16. Mendel Leisk
    42,369
    That “firing up” is very, very likely the electric motors turning it, courtesy of the hybrid battery. Keep at it long enough and you’ll add a depleted hybrid battery to the issues.
  17. ChapmanF
    19,050
    It's a plug-in. So, they can plug it in.
  18. bisco
    52,888
    firing up might be misleading. trying to start, if you're getting any spark/fuel/compression, you might smell combustion, even though it shuts itself down because it is incomplete and the computers don't like that.
    were the plugs changed at 120k?
  19. William Lower
    Dixon, California
    2013 Prius v wagon
    Good question. Yes, the spark plugs were changed at 120K miles.
  20. nicoj36
    nicoj36 Active Member
    518
    162
    Might just be a clogged fuel system, engine air-filter, and MAF sensor.
    Try giving it a bottle of Chevrolet fuel cleaner with a full tank of premium gas. And clean the MAF sensor. Good luck.
