HV Battery Date Code
Discussion in 'Knowledge Base Articles Discussion' started by ITBland, Aug 26, 2018.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,219
    5,903
    Columbia, SC
    H20ZW
    20 = day of month
    Z = month (December)
    W = year (2019)
    If a W was on a module, it would signify 2 years later (2021) for the manufacture date.
    So it looks like your car has an OEM replacement with a manufacture date of 12/20/2019
    If you were to peak at a module, the letter code should show a manufacture date within about 2 months of the exterior date. The letter code should be a U for 2019.
    PriusDadNoob likes this.
  2. PriusDadNoob
    PriusDadNoob Junior Member
    62
    Thank you so much @TMR-JWAP I was a little confused on which sticker I had and now I get it.
    This is great news for me too since I was not sure if it was an original!
  3. PriusOwner428
    PriusOwner428 Junior Member
    40
    IL
    It's probably a 12/20/2021 battery
  4. TMR-JWAP
    6,219
    5,903
    Columbia, SC
    or probably not...
    Please refer to post #21
  5. Shakhawat
    Shakhawat New Member
    Bangladesh
    2015 Aqua
    Business Edition
    Would you please help me to identify regarding this batteries manufacture date?
  6. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    251Y
    25 = day of month
    1 = month (January)
    Y = year (2023)
    This module has a manufacture date of 25 Jan 2023, so pretty new.
  7. Mpdcnva
    Mpdcnva Member
    27
    Washington dc
    Four Touring
    066Y pack for 1655 dollars. June 6, 2023?
  8. Kris_Parker
    Kris_Parker Junior Member
    96
    Chicago, IL
    Hello, if you have can you share this new decode please?
  9. dolj
    dolj Senior Member
    7,645
    3,858
    Sure.
    This image and the decoding information were originally posted by (IIRC) TMR-JWAP. (My apologies to the OP if I'm not recalling correctly.)
    I marked it up and notated it for my own quick reference.
    I hope that helps.
    A quick question for anyone who knows, I just noticed J at pos 3 and H at pos 5. Is pos 3 the manufacturer code and pos 5 the model code?
    Note also, that there is a newer again serial number format for which I have not seen any decoding information, so if anyone has worked that out, it would be good to add to this post.
    #29 dolj, Apr 2, 2024
    gsv and Kris_Parker like this.
  10. Kris_Parker
    96
    Chicago, IL
    Thank you dolj! This is exactly what I was looking for.
  11. Prius RT
    Prius RT Member
    114
    Help needed:
    My serial number is 0f2pa4247031m1e1j0000031
    When was this manufactured ?
    Hopefully not anywhere close to 2007
  12. dolj
    dolj Senior Member
    7,645
    3,858
    The Toyota label has 240118 printed on it. That may be 24 Jan 2018 if in DDMMYY format. It could equally be 18 Jan 2024 if in YYMMDD format. Neither date is close to 2007.
    When did you buy the battery?
