How to make the HV battery fan to run all the time?
Discussion in 'Prime Main Forum (2017-2022)' started by ESh, May 23, 2023.
  1. ESh
    ESh Junior Member
    MI
    2020 Prius
    Luxury
    Is there any possible way to make the fan run all the time, automatically, without using Dr. Prius or similar app?
    The idea is to net let the battery run hot.
    Thanks.
    douglasjre and Plugin_RK like this.
  2. Plugin_RK
    Plugin_RK Member
    100
    31
    Pacific Coastal city
    2018 Prius PHV
    This is an interesting idea. Toyota's goal is probably to reduce energy consumption and only use the fan when it is most effective.
    I used to have a Hewlett Packard business laptop with a fan that was off most of the time. The fan didn't run mostly and allowed the temperature to build up until it was hot esp. for the CPU, then the fan turned on - unfortunately the fan was unpleasantly loud. So, HP made a firmware modification allowing the user to choose to run the fan at low speed permanently as an option, which many users enabled. This was great as it reduced fan noise dramatically, indicating presumably that the laptop was seldom operating at higher temperatures (... but at the expense of increased energy use).
    So, your suggestion might similarly result in lower average HV battery temperature. Presumably, this would incur slightly higher energy usage but this may be of no concern e.g. if your daily commute doesn't deplete the battery. For example, my daily commute to work leaves between about 10% and 20% battery level depending on season, etc.
    #2 Plugin_RK, May 27, 2023
  3. bisco
    52,315
    i know you can run the fan with a scan gauge, but idk if you can run it manually
  4. Plugin_RK
    Plugin_RK Member
    100
    31
    2018 Prius PHV
    Could it be as simple as connecting the fan via a manual switch to a suitable power source in the car i.e. bypass the automatic control?
    Frankusa94 likes this.
  5. bisco
    52,315
    idk, the fan speed is controlled by the attached logic board, so you would have to now something about the electronics.
  6. Plugin_RK
    Plugin_RK Member
    100
    31
    2018 Prius PHV
    It would depend on the type of fan. Many older fans just required power to their terminals and they'd run, which would bypass any electronics completely.
    That's not always the case though. There might also be a sensor detecting whether the fan runs or not to protect against loss of cooling leading to battery overheating. Someone will know, unfortunately I don't.
    douglasjre and bisco like this.
  7. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    A possible work around would be to mount a small fan over the air inlet and have it run whenever the car was on. The existing fan could still come on if needed.
  8. Leadfoot J. McCoalroller
    8,134
    7,639
    Pennsylvania
    2018 Prius c
    Part of making a fan that only runs as much as needed is so that the item to be cooled gets exactly enough cooling.
    Another part of it is making sure the fan lasts as long as the rest of the car.
    If you do rig your fan to run full-time, make a reminder to check on it periodically, because it might not last as long as it was originally designed to.
    Trollbait and Mendel Leisk like this.
  9. Mendel Leisk
    41,843
    A little cooling is good, so more is better? Maybe yes; maybe no?
    The fan is also multi-speed, about five speeds IIRC: so full speed all the time?
    I’d think Toyota’s engineers thought a lot about this, dialled in fan activation and speed carefully.
  10. rjparker
    10,426
    6,530
    Sometimes the battery needs to be warmed up so forcing full speed fan will slow that process. Remember the battery is not a human who performs better at 72f.
  11. bisco
    52,315
    can a battery receive too much cooling, outside of cold weather?
  12. Leadfoot J. McCoalroller
    8,134
    7,639
    Pennsylvania
    2018 Prius c
    It can receive too much dust. More air means more dust.
  13. bisco
    52,315
    interesting, i never thought of that
  14. prius16
    prius16 Active Member
    462
    246
    New England
    2022 Prius Prime
  15. rjparker
    10,426
    6,530
    EV range is different than an air cooled hybrid battery's best operating temp. EVs use battery power to heat the cabin and to heat or cool the battery. Running a hybrid battery's fan faster than necessary (which varies) just reduces efficiency and increases fan wear and blower accumulations. If a hv battery is overheating its usually a clogged blower or a really bad battery.
  16. prius16
    462
    246
    New England
    2022 Prius Prime
    Sorry, there isn't anything magic or special about the hybrid or EV batteries that Toyota uses.
    Yes, every vehicle manufacture has there own very specific requirements.
    However, the general uses/limitations exist.
    Battery temperature is battery temperature.
    I'm not going to argue, or debate, something extremely basic, and super well known.
    Google.....
  17. Mendel Leisk
    41,843
    I had a Scangauge monitoring the middle temp sensor on hybrid battery (on our ‘10). I recall one cool evening, driving a quiet coastal highway, on a cool evening, around 80 kms (50 miles) an hour. The sensor temp stabilized around 35C, while ambient was maybe 18C. That seemed a baseline case, what the engineers were aiming for?
  18. bisco
    52,315
  19. Frankusa94
    Frankusa94 Junior Member
    60
    Ma
    You can use app called hybrid assistant...set the fan kick on temp to lowest range and the fan will run much more...you will need a cheap Bluetooth odbII adapter to communicate with the car.
    I am currently using this setup on my 2007 prius as the onboard fan control doesn't run the fan ever!...causing hv battery to run too hot and triggering a ecu error code for hv high temp warning... I am still looking for what controls the fan on/off..as that componet might be bad.
    Frank
  20. Frankusa94
    60
    Ma
    Hi Mendel, any idea what controls the hv battery fan? I have a 2007 that will never turn on the fan...resulting in high battery temp warning light. I have temporarily solved this by using a 3rd party app called Hybrid assistant ... which Manages the fan perfectly. I would like to ultimately fix the toyota onboard fan control... but don't know where or what it is.
    Any thoughts?
    Thanks
    Frank
