Dr prius weak block detected: 7
Discussion in 'Gen 3 Prius Fuel Economy' started by Darklandscape, May 28, 2023.
  1. Darklandscape
    Darklandscape Junior Member
    64
    Hi I've ran the dr Prius battery life expectancy test and it gave me a warning that a weak block was detected.
    I also drove and tested the voltage difference and I saw it go up to 0.40 and would jump to 0.25 quite often
    Is that a really bad sign?
    I've also seen the pack voltage go to 265v and drop down to 198v.
    Do you think the battery could be the cause of a 6-7 mpg drop in the last 7 months?
    The engine sounds like its working louder and harder lately.
  2. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    Yes. Very much so. Check and see if your hybrid battery fan is clean...and the fan filter in the side of the rear passenger seat is clean as well. And start saving for a new hybrid battery.
  3. bisco
    52,220
    maybe, but most report no problems before you get a battery code
  4. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Never mind th3 hv battery, get your egr circuit cleaned!!!!
  5. Darklandscape
    64
    I am planning too.
    Did you bring it up because I said the engine is working louder and harder ?
  6. DirkAshburn
    DirkAshburn Member
    157
    65
    Virginia
    Beyond a (possibly bad? - don't know) block, your battery looks fine. Mine reported 48% about 9 months ago and I'm still getting a steady 39mpg in town. I'm just waiting for it to give the red triangle of death but it's been holding out ok.
    #6 DirkAshburn, May 28, 2023
  7. Darklandscape
    64
    I'm getting 31-32
    It went down like 6-7 mpg in the last 7 months
  8. bisco
    52,220
    the prolong charger gets good reviews here, but it's unclear how long it will prolong the life of each individual battery.
    you can try that route (not cheap) or just wait and replace it when the time comes.
  9. bisco
    52,220
    there are so many things that can affect gas mileage. tires, brakes, injectors, plugs, coils, throttle body, maf, filters and etc.
    Grit likes this.
  10. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    No. I’m just echoing what others say here on the regular . Louder engine had no factor.
  11. Darklandscape
    64
    The only things I haven't checked from here are injectors and coils, I did run techron and some other stuff multiple times in the gas tank.
  12. DirkAshburn
    DirkAshburn Member
    157
    65
    Virginia
    Check the rear brakes too. Although I did a check last summer, I just got mine replaced (brakes and rotors) and mpg went form 36 to 39.
  13. Darklandscape
    64
    After doing more testing another weak block was detected.
    So block 7 and block 4 are weak.
