Most Obscure Prius Facts (Way out there)
Discussion in 'Gen 2 Prius Main Forum' started by 200Volts, Nov 20, 2006.
  1. Orf
    Orf New Member
    414
    Devonport, Tasmania
    <div class='quotetop'>QUOTE(Mr07Touring @ Dec 6 2006, 02:15 AM) [snapback]358343[/snapback]</div>
    The speed increment seems to be a factor of how long you hold the lever. Tap it gives 1 MPH, hold for 1 second give 2 MPH. You can even speed up or slow down by holding it until the speed that you want is reached.
    <div class='quotetop'>QUOTE(windstrings @ Dec 5 2006, 09:56 PM) [snapback]358257[/snapback]</div>
    Did you have the route memory turned on?
    I would not have thought that it would make any difference but it might.
  2. jrana
    jrana New Member
    <div class='quotetop'>QUOTE(Cant think of a cool name @ Nov 21 2006, 05:23 PM) [snapback]352747[/snapback]</div>
  3. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(cliffdvr @ Dec 7 2006, 11:15 PM) [snapback]359155[/snapback]</div>
    Yep. that was on an older post.. also you can hit your up or down and hold it to change to the next CD's.
  4. Renocat
    Renocat Member
    363
    Rochester, NY
    <div class='quotetop'>QUOTE(Sarge @ Dec 5 2006, 03:31 PM) [snapback]358106[/snapback]</div>
    The voice is actually Microsoft Jill. SHe is used in several text to voice software programs. We use such a program at school for special ed students and it is weird to hear "my Prius" reading a students paper or an internet site :lol:
  5. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I'm very amused by people using the navi to get directions, but at the same time ignoring said directions.
    To be fair though, I've done a similar thing where maybe the beginning or end of the route is unknown so I follow Jill's advice, but on the known end I go my own way.
  6. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Ichabod @ Dec 8 2006, 10:27 AM) [snapback]359273[/snapback]</div>
    If I know how to get where I'm going, I don't use the Navi.
    If I don't know, I use the Navi. However, I already know how to get to the highway from my house, so I ignored its rather roundabout way (until it learned my favorite way, but I still ignore it). I only pay attention once I'm near my destination.
    Also, when I'm in Boston, because of construction the way is different every time, I have no choice but to ignore the Navi (which annoys me, because that's where I need it most).
  7. archermoo
    archermoo New Member
    118
    Pittsburg, CA
    <div class='quotetop'>QUOTE(Mr07Touring @ Dec 5 2006, 11:15 PM) [snapback]358343[/snapback]</div>
    All of the previous Toyotas that I have owned with cruise control have changed in 1 MPG increments. This includes a 2000 RAV4 and a 2003 Highlander. The 78 Celica didn't have cruise. :)
  8. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(Ichabod @ Dec 8 2006, 09:27 AM) [snapback]359273[/snapback]</div>
    Its a guy thing.... :lol:
  9. whodat
    whodat Member
    117
    Aptos, CA
    <div class='quotetop'>QUOTE(klevitsky @ Nov 21 2006, 11:45 AM) [snapback]352662[/snapback]</div>
    I've successfully float charged my 2006 Prius from the positive post in the front fuse box under the head. Its much more convenient than the rear battery access.
  10. fphinney
    fphinney Member
    234
    Walnut Creek CA
    Had our Prius about 6 months now.
    Just discovered that there (at least) 5 different ways to lock the car.
    1. Fob
    2. Metal key
    3. Press an exterior 'black button'
    4. Press 'Lock/Unlock' rocker switch located by window buttons
    5. I just discovered (red) button by interior door handle.
  11. Cheap!
    Cheap! New Member
    1,157
    When you just start your car and put it in reverse the rearview camera comes on, and then when you hit the EV button (Mod) the screen jumps to the energy screen. Then when you push your anytime rearview camera button (Another Mod) the rearview camera will not come on. You first have to put it into neutral and then back into reverse to get the camera back.
    Another Obscure Prius Fact is that it is way to easy to mod!
    :D
  12. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(Renocat @ Dec 8 2006, 05:55 AM) [snapback]359245[/snapback]</div>
    Oh no!!! There's Microsoft programming in the Prius. :eek:
    Hopefully it's limited to Microsoft Jill . . . in that case, the worst we could expect is a bout of Tourette Syndrome, and not a serious crash. :lol:
  13. windstrings
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Dec 9 2006, 04:21 AM) [snapback]359660[/snapback]</div>
    We're doomed..... a virus!
  14. jaguaraja
    jaguaraja New Member
    147
    Long Island, NY
    Hopefully Microsoft Jill is in no way related to Microsoft Bob. (those of you that used MS Bob will know what I mean).
  15. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(fphinney @ Dec 8 2006, 10:26 PM) [snapback]359641[/snapback]</div>
    I'd never noticed the red button, and I usually use the black exterior buttons. I hope the rubber covering doesn't wear out. I do alternate between driver door, hatch door and passenger door though.
    I'll have to check out the red button. Thanks for the new info.
    Dave M.
  16. Tideland Prius
    16,493
    <div class='quotetop'>QUOTE(dmckinstry @ Dec 9 2006, 09:29 AM) [snapback]359744[/snapback]</div>
    It's basically the door lock itself lol. It has a red sticker so you know whether it's in the lock or unlock position.
  17. Kestrel
    Kestrel Bird geek
    59
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(sseres @ Dec 6 2006, 04:12 AM) [snapback]358713[/snapback]</div>
    It also fits behind the center console--flip down the rear cup holder arm, and place it over the first one. There are even guides to hold it in from the top!
  18. busyrosy
    busyrosy New Member
    113
    Bay Area, CA
    while you are in reverse to get out of your spot, and then you pause for a bit to adjust the climate control, your rear view camera doesn't work anymore (unless you change to D and then do R again)
  19. kimgh
    kimgh Member
    297
    San Jose, CA
    <div class='quotetop'>QUOTE(PriusRos @ Dec 7 2006, 12:59 PM) [snapback]359015[/snapback]</div>
    Hmmm, I tried. How does it come off? and if it does, will it go back on again? Seems to be pretty permanently attached to me...
    <div class='quotetop'>QUOTE(Tideland Prius @ Dec 9 2006, 01:30 PM) [snapback]359851[/snapback]</div>
    I would caution that I don't think this way of locking will lock ALL the doors...
    Didn't for me, anyway...
  20. fphinney
    fphinney Member
    234
    Walnut Creek CA
