Shield part identification
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by butzodaddy, May 30, 2023.
  1. butzodaddy
    butzodaddy Junior Member
  2. Tombukt2
    9,075
    1,574
    Exhaust heat shield save it as a souvenir I doubt you'll get it back on the car and not sure why you'd want to
    SFO likes this.
  3. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    Generally, heat shields are installed to protect parts that shouldn't get hot. It's up to you whether you will reinstall it.
  4. Tombukt2
    9,075
    1,574
    To get that one back on is going to be rather tricky to make it not rattle and make general noise
  5. Mendel Leisk
    38,706
    If you decide to reinstall, to bridge the torn-out zones, you could try fender washers:
    Or short pieces of pipe hanger strapping:
    For the latter, you could even try two pieces, stacked like an "X".
