Leaking from oil pressure sensor?
Discussion in 'Gen 3 Prius Main Forum' started by unigeezer, May 31, 2023.
  1. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Lately I've noticed oil drops on my driveway and I looked underneath and it looks like it's all concentrated around the oil pressure sensor. Could this be the reason for the oil leak? Here are a couple of pictures. IMG_20230531_132401.jpg IMG_20230531_132537.jpg
  2. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    those are known to spring leaks like that, and your pictures appear to support it.
  3. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Does it take a specific type of socket to remove the sensor?
  4. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    I found this on YouTube, so hopefully this helps:
  5. DPri
    DPri Junior Member
    40
    Earth
    Had similar problem. Mine was leaking from above chain tensioner down to oil pressure sensor.
    #5 DPri, Jun 1, 2023
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,497
    2,481
    Taylors, SC
    The housing of the sender uses a gasket that surrounds the plastic of the expectrical components of the sender. The gasket appears to have developed a leak. The metal body of the sender is made of thin metal and can be easily deformed if not installed with a special oil sender socket.
  7. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    I'm wondering if a socket with a 3/8" drive would be easier to get into the confined space versus a half inch drive? I see 24mm deep sockets are typically used to remove the oil pressure switch but most come with a 1/2" drive and it's just that larger ratchet will be harder to maneuver in that limited space.
  8. Mendel Leisk
    41,820
    You could add a 1/2"-to-3/8" adapter, but that will add length. Maybe that's good anyway; you want to use an extension? Repair Manual info in attached:
  9. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    I found this one, which should be perfect for the job. And at just $8, it's a good deal too!
  10. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    While waiting for Amazon to deliver the 24 mm deep socket tomorrow, after removing the passenger side front wheel and that little panel I was able to access the oil pressure switch very easily. I was able to remove it without any problem using a crescent wrench. So since I can't use a torque wrench until tomorrow to double check the tightness, should the threads disappear or should some still be showing after installing the new switch?
    **Also, in the linked pdf it states that after installing a new pressure sensor switch you should not start the car for at least an hour. There was no reason indicated so I'm wondering why you should wait an hour before starting your car?
    #10 unigeezer, Jun 1, 2023
  11. taxidriver50005
    taxidriver50005 Active Member
    204
    170
    GB
    Excel
    I just used a spanner.. Replaced and fired it up no problems... Never heard of not starting for an hour
  12. ChapmanF
    18,449
    The earlier step in the instructions is to put Three Bond 1344 on the new sensor threads. The hour after installation is for the 1344 to set before putting oil pressure on it.
  13. unigeezer
    unigeezer Member
    228
    63
    torrance, ca
    Ok, that makes sense, but the replacement sensor I bought from autozone already comes with that white thread locker tape on it. Not sure but it looks like teflon. Seems to be doing the job as no leaks detected after 3 days.
    #13 unigeezer, Jun 5, 2023
  14. Bevpower
    Bevpower Junior Member
    Medford oregon
    I am just now having this problem. Where did you get your part? Were any threads showing after install?
  15. Leadfoot J. McCoalroller
    8,133
    7,630
    Pennsylvania
    2018 Prius c
    Be super careful installing. That's a tapered thread, so overtorquing the sensor almost guarantees a cracked block.
