Prius totalled
Discussion in 'Gen 2 Prius Main Forum' started by calpal, Dec 9, 2006.
  1. calpal
    calpal New Member
    52
    Someone made an abrupt u-turn in front of me. I struck him broad side at about 40-45 mpg. The air bag did not deploy. Should it have?
  2. naterprius
    naterprius Senior Member
    1,843
    Not if you are okay! Airbags are extremely dangerous and can cause harm. Typically, then can save your life if the seat belt isn't good enough. Since you are writing to us, I suppose you are okay, so no, be glad the bag didn't go off.
    P.S. I doubt you really hit him at 40. You probably slammed the brakes and actually hit at a much slower speed.
    Nate
  3. Tideland Prius
    16,604
    The full name of airbags is Supplemental Restraint System (SRS) airbags. They're meant to supplement the seatbelts. If the seatbelt was sufficient to minimise injury, then there's no need for them to go off. Besides, that's one less (or rather two) thing to have replaced!
  4. mikep01
    mikep01 New Member
    lets see pics of your car. if it is not centered the tha air bags wont go off
  5. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    <div class='quotetop'>QUOTE(mikep01 @ Dec 9 2006, 02:35 AM) [snapback]359651[/snapback]</div>
    Thats not true, it depends on the decelerational force, take a look at offset crash tests, not centered and the airbags deploy.
  6. john1701a
    john1701a Prius Guru
    12,820
    5,305
    58
    Thank goodness the days of airbags deploying (when not needed) and always at the same rate (220 MPH) are over.
    Sensors & Behavior have become far more fitting to the situation at hand, aware of the circumstances rather than a one-size-fits-all approach.
    If the airbags did not deploy and you didn't sustain any serious injury, great! Consider that unnecessary use will still result in the usual minor rubs & burns from the airbag itself, not the accident.
  7. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    sorry about your accident, and i'm glad to see you're well enough to write to us.
    that said, i never fail to be amused when i read the fairly common complaint of "my airbag didn't go off!"
    airbags are dangerous things, they can really hurt you. they are designed to not go off unless they are truly needed. the risk:benefit ratio has to be favorable for the vehicle occupant.
    there would be much more to complain about if the airbags went off in all situations: lots and lots of unnecessary injuries, a higher likelihood of a car being totaled in an otherwise rather simple damage situation, and the associated increased insurance premiums across the board. airbags are not cheap and there are a few other related components that need to be replaced every time the airbags go off. plus most places charge quite a bit for labor to replace them because of the huge danger to the technician and the fact that many won't touch one with a 10 foot pole.
    since you are well enough to write to us, you probably didn't need that airbag. best wishes healing up from any injuries you have have sustained and in sorting out the insurance mess.
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    I've been slapped by an angry airbag before. :)
    Glad to see you are ok enough to be up and typing. Sorry to hear about the car though. :(
  9. chogan
    chogan New Member
    590
    Vienna, VA
    I have the very bad habit of driving the car as I was taught, with hands on the wheel at 10 o'clock and 2'oclock, or, worse, with one hand on the wheel at 12 o'clock. An apparently well-informed friend told me that a) they teach kids to hold the wheel at the bottom now (4 and 8 o'clock), and B) that I will definitely break one or both arms and/or my face if I have the steering-wheel-mounted airbag go off while holding the wheel in my old-fashioned way. I can't believe I'm the only guy who does this. And, apparently, the National Highway Transportation Safety Administration has not taken a position on this.
    So, anybody know of any actual data on this, meaning, broken arms during airbag deployments, with injury attributed to using the traditional 10-2 position for steering? Or is it just one of those things that seems plausible but doesn't work that way in practice?
  10. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Never seen a pt. in my ED where a broken bone was attributable to the air bag. The arms should/would be pushed outward and upward (10/2 position) or downward (4/8 position).
  11. Tideland Prius
    16,604
    <div class='quotetop'>QUOTE(chogan @ Dec 9 2006, 11:52 AM) [snapback]359805[/snapback]</div>
    Well the issue is that the airbag may fling your hand towards your face. Having it at 9-3 or 8-4 puts your hands out of the way of the airbag. It's also easier to brace yourself for an impact.
    I've been taught 10-2 but have since used 9-3. For me, it gives me better control of the vehicle because if I were to turn the wheel to do an evasive manoeuvre, having it at 10-2 may cause me to turn more than necessary, thus increasing the chance of upsetting the balance of the car. With 9-3, you can better tell where your wheels are pointing.
    Also, I attended a few BMW events (one was an xDrive Comparison event). I used 9-3 to navigate the auto-cross circuit and 9-3 allowed me to test the vehicle's limit on the slalom better (although, in all except one of the runs, I think I reached my limit first before the vehicle's).
  12. daniel
    14,487
    1,519
    Spokane, WA
    If the air bag did not deploy and you were not injured, then it should not have deployed and the system performed properly. I hope this was the case. Your post does not say.
  13. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Here's something I was taught at a Volvo-sponsored driving class in 1998.
    Many people make turns using an underhand grip at the top of the wheel to turn it. Doing so almost guarantees severe injury should the airbag deploy during the turn. Because there would be no time to release your underhand grip and move your arm, the airbag can shatter your hand, wrist, and forearm.
    Since then I have learned to never use an underhand grip in turns. Every little bit helps.
