Slip indicator light when going about 60mph
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Grayson73, Oct 8, 2015.
  1. Gino Veltri
    Gino Veltri Member
    413
    40
    I have this issue too and all my tires are the same size. Is the wheel speed sensor the same as the abs sensor
  2. fuzzy1
    10,588
    Same brand and model too, not just nominal tire size?
    Even with the same marked tire size, different models can have surprisingly different revolutions-per-mile specs.
  3. Gino Veltri
    Gino Veltri Member
    413
    40
    I stand corrected one is a 195 65 r15
  4. Gino Veltri
    Gino Veltri Member
    413
    40
    Is the speed sensor the same as abs sensor?
  5. fuzzy1
    10,588
    So the car senses that it is not spinning at the same rate as the others, so thinks that it is slipping.
  6. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    What's the size of the other 3 tires?
