little white wire
Discussion in 'Gen 2 Prius Main Forum' started by deafelf, Jun 2, 2023.
  1. deafelf
    deafelf New Member
    Mississippi
    Does anyone know what this wire does?
  2. Tombukt2
    8,062
    1,395
    Yes that's supposed to go to a little plug that is plugged in right near that fuse somebody will be along in a second and show you a picture of one and a good car My pictures are all too high resolution and have to be messed with to post them
  3. PriusCamper
    PriusCamper Senior Member
    10,897
    4,418
    Pacific Northwest, USA
    Wow, there must be alot of dirt roads where you live... So dusty!
    ColoradoCrow likes this.
  4. Tombukt2
    8,062
    1,395
    Lot of dust in Mississippi the back roads and all dirt roads almost like the red clay of North Carolina
  5. PriusCamper
    10,897
    4,418
    I had a Prius from rural Idaho I was working on for a while... Looked just like this. I couldn't stand it. I insisted on cleaning it up before I'd work on it. That was back when I convinced myself that I'd only work on clean Prius and the Universe was like, "Now I'm going to connect you with the dirtiest Prius I can find." YIkes!
  6. Tombukt2
    8,062
    1,395
    Yeah same here I have to blow and spray mine down before I really start working on it just to get all the dust off so I can see the labels and stuff whatever
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,089
    5,806
    Columbia, SC
    It goes to the DC-DC converter inside the engine compartment inverter assembly. It's exact purpose? Battery voltage sensing for the inverter? You really need to fix that.
    Tombukt2 and PriusCamper like this.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Like TMR said its a sensing wire. Surprised its not throwing a check engine light on the dash with it disconnected.
    Here's a pic.
    2 wires plug into that battery top mounted fuse assy one is the thick main 12 volt B+ cable that runs to the front jump point and has a 100 amp fuse the other wire is the one in question that has a 5 amp fuse as its just sampling the battery voltage.
  9. Tombukt2
    8,062
    1,395
    When I undid mine by a mistake actually I hit it with something in the wire broke off the connector I had some light on until that was restored that I do know and I restored that connection immediately did not cap it off and leave it no sir
