EGR valve or timing chain or sensors or ECM
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Risky1, Feb 26, 2023.
  1. Risky1
    Risky1 Junior Member
    Visalia, CA
    Background:
    2010 Prius 265k miles. 6k miles since head gasket and timing chain and EGR/EGR cooler and intake cleaning (very thorough). Ran great since then... Until...
    Current
    Started with intermittent (1-2x week) severe stumble/rough running, at idle after warm up and in low rpm. At speed 45+. Seems to go away. CEL comes on and then after the car sits for a bit, it starts and runs just fine.
    Codes are:
    P0016 - cam/crank correlation
    P0340 - camshaft position sensor bank A
    P0403 -egr circuit malfunction
    The codes would clear themselves after the first few times, then it would do it again within a day or two.
    Now, when the car starts it seems to run fine, then after a min or two, it begins the EGR rumble and stumble. If I shut the car off and restart it runs fine again for a min then starts the really rough running.
    So, my thinking was this. If the cam chain slipped a tooth, the problem wouldn't be intermittent right? It would be off and run like it's missing right from the first rotation of the motor, no? but if the tensioner was not working correctly, it could be a half tooth off and possibly compensating for the timing being slightly off, until it can't...
    But the rough running was identical to the EGR issues in the past, so I purchased a new OEM EGR valve and cleaned the intakes again. Result was no change.
    My next thought is that it might be an ECM issue as I've heard that these go bad and cause a number of the same problems in relation to the EGR circuit issue.
    Before I open the timing chain cover and get into that, I thought possibly a cam chain sensor, but I doubt that would cause the code for the cam and crank sensor correlation issue, this leads me to think the tensioner has allows the chain to be a 1/2 tooth off, and maybe that's why it still seems to run fine when it was running?
    So. New OEM toyota EGR valve and solenoid -no change, still have code for EGR circuit.
    Nest step? Cam sensor or ECM? Or just dig in and address the possible timing chain and tensioner? I hate throwing parts, but I also hate paying for diagnostic and then paying for parts anyway when they will mostly come back with "it may be a couple things but we won't know for sure until we get into it..."
    I bought what I thought was a quality timing chain kit when it was done with the head gasket? Maybe it wasn't and something failed, or maybe I did it wrong? But it ran great for 6k miles afterwards....
    Maybe the ECM has taken a dump? Maybe all of the above at the same time?
    #1 Risky1, Feb 26, 2023
  2. Tombukt2
    12,884
    2,315
    Is the engine casting assemblies all intact and fine no cracking along the back center section all of the business that goes on with these when the engine literally comes apart cracks whatever. I guess what I'm asking is there any flex or added flex in the already poor designed open deck assembly like white cracking on the back side just under the head which is where they all seem to get stressed as they begin to do the water dance or whatever's going on in there.?
  3. Mendel Leisk
    41,255
    Who did the work?
  4. Risky1
    Visalia, CA
    As far as I could tell the block's fine as well as the head. I don't lose any coolant. There's no pink milkshake in the oil there's no oil in the coolant. The car wasn't overheating and it doesn't leak oil.
  5. Risky1
    Visalia, CA
    I did the work. I've done plenty of timing chains including Prius. I've owned three. Not an expert but I know enough to make myself dangerous... obviously.
    Tombukt2 and Mendel Leisk like this.
  6. ChapmanF
    18,019
    You've got at least two different things going on here. The P0016 and P0340 are plausibly related. P0403 is a problem in the electrical circuitry controlling the EGR valve, and ought not take very long to put right, which at least would get one distraction out of your way while dealing with the valve timing issues, which could be more of a puzzler.
    Sometimes the hardest thing during diagnosis is to avoid distracting yourself with things that aren't established yet. Even being careful not to say something like "the EGR rumble and stumble", until you've tested and established that EGR is causing it, can be important for keeping your thinking clear.
    A P0403 makes the ECM discontinue any use of the EGR valve, so if that code is up, it shifts the odds in favor of the rumble being something else. (Unless the valve was open when the circuits failed, and is now left that way, but symptoms of that might be more constant.)
  7. Risky1
    Visalia, CA
    This I understand, with a new OEM EGR valve and solenoid installed and the intake cleaned, and the EGR cooler cleaned put to ensure no blockage, (that took a long time with a bucket of chem dip and small pipe cleaner I made myself to get into the small passageways) I highly doubt it's the EGR valve... most likely the ECM or wiring harness to the EGR.
    But would a slipped chain have an intermittent rough running issue? I would think if it s slipped a tooth, then the issue will be there hot or cold, no?
  8. ChapmanF
    18,019
    The relationship between chain and sprockets, if it's off, will always be off the same amount, but perhaps it affects the engine differently under different running conditions, or different parts of the intake timing adjustment range. Then again, the chain being actually off might not be the only possible cause of those codes.
    In any case, the electrical tests to find the cause of the P0403 are straightforward, and then the troubleshooting steps for P0016 and P0340 should suggest how to see what's happening there.
    For what it's worth, there is no solenoid associated with the EGR valve. Its actuator is a stepper motor.
  9. Risky1
    Visalia, CA
    I put it in neutral and it idled fine. Wouldn't increase RPM because the check engine lights and etc all can back on, but it idled in neutral great! Put it in drive with foot on the brake and it started the violent sharing and stumbling, back to neutral, and it idled fine. Back to park and it started shaking and stumbling again.
    Shut it off. Cleared the codes.
    Started it again. Same behavior as before. Starts. And runs like it great for about 10 seconds then suddenly doesn't know what time it is... in neutral, purrs like it's supposed to, into park and shakes and misses like before.
    Initially when I say the broken sprocket and sloppy crank sensor plate, I thought that may have been the reason this all started. The crank sensor couldn't consistently pick up the timing and confused everything things else. Now Part of me thinks that this violent shaking and stumbling may have been what broke the sprocket and allowed the key way for the sensor to get sloppy.
    So here I am. With the codes above showing.
    Could the ECM be bad? What else could be the issue? The oil drained had no coolant. The coolant had no oil.
    I need help further diagnosis.. I am pretty handy.. I know enough to get my self in trouble.. as you can see.
    Is there something I can do without tearing down the timing chain cover again?
    Edited .. added the below info. I have found that the 12v battery will not hold a charge so I think it was only starting under the power of the jump pack and not the battery. Once the 60.seconds of "start engine" power from the jump pack, times out. The motor dies. Of course in neutral the traction battery does not charge and I can't keep it running in park because of the violent shaking. Could it be just really weak spark? Would the spark voltage required change from park to neutral? It seems so odd that neutral seems to run fine but park/drive no Bueno..
  10. bisco
    51,811
    codes and reader?
  11. Mendel Leisk
    41,255
    This is a third gen, not a 2006 like your avatar? If so:
    What's the miles on it?
    Ever cleaned the EGR components and intake manifold?
    Did you mean to post a pic:
  12. ChapmanF
    18,019
    In neutral there is no load on the engine. Same for the first 10 seconds or so after starting. Otherwise, in Park, the engine often isn't really idling; it's running at idle RPM but under load, to make charge for the battery. Sounds like the shorter way to say what you're seeing is "runs rough under load".
    The usual tree of reasons for rough running under load should be worked through. Because of the way the engine and transmission interact, there isn't much "mild" rough running in a Prius; it'll pretty much always sound like the end of the world.
  13. Mr. F
    Mr. F Active Member
    388
    255
    Washington
    Likely a continuation of OP's previous thread. If so, would highly recommend continuing the discussion there, or asking a mod to merge the threads using the Report button.
  14. Mendel Leisk
    41,255
    ^ Missed that, concur.
  15. Risky1
    Visalia, CA
    I am not sure what happened to the first few paragraphs of my original post. Yes. a lot of information is missing that was suppoosed to be there. sorry.
    It is a contuinuation i will ask to have them merged
    here it is
    P0016 P0340 P0403 P3190
    Back story: Car was running fine, then, one day it started running like it was missing terribly, warning light, check engine, etc. It ran similar to this event before and we figured out it was the egr cooler fully plugged, and. EGR valve. These were replaced. Car ran fine for a while.
    Then we had a head gasket issue. We replaced the head gasket. Car ran fine for a while.
    Brings us to current event.
    Driving fine then terrible running, shaking, dash lights up, won't run. This was six months ago. It has sat since then.
    At the time, the codes were related to the timing/crank and can sensors being out of sync. EGR, and low engine power. (Same codes as now)
    I assumed that the chain, which had never been replaced as far as we know (bought used about 50k ago) either was stretched, the tensioner was bad or possibly slipped a tooth etc. So, this past week I did the timing chain. New Toyota OEM chain, guides, tensioner, timing sprockets, oil sprockets, oil pump chain. The works.
    When disassembling the crank timing oil chain sprocket was found broken right at the keyway. The crank sensor timing plate behind it, they key was all hammered and the timing sensor plate was sloppy on the crank because the keyway was hammered. This is something I have never seen, granted I've only done about a dozen timing belts and chains in the last 30 years, so I have very limited experience. Anyway, I ordered a new sensor plate from Toyota. I had the new sprocket already.
    I assembled everything. Ensuring that the cams and crank were timed correctly, then before putting the covers back on permanently, I spun it by hand and ensured that the crank pulley/dampener and timing marks on the cam sprockets all lined up as they were supposed to. All looked great, so I put it all back together. Car batteries were dead. Of course from sitting so long. Charged the 12volt, and then turned the car on. It started.
    Ran and purred like a kitten for about 10 seconds then started running like it was missing terribly. Shaking etc. I put it in neutral and it idled fine. Wouldn't increase RPM because the check engine lights and etc all can back on, (limp mode i am sure) but it idled in neutral great! Put it in drive with foot on the brake and it started the violent sharing and stumbling, back to neutral, and it idled fine. Back to park and it started shaking and stumbling again.
    Shut it off. Cleared the codes. Started it again. Same behavior as before. Starts. And runs like it great for about 10 seconds then suddenly doesn't know what time it is... in neutral, purrs like it's supposed to, into park and shakes and misses like before.
    Initially when I saw the broken sprocket and sloppy crank sensor plate, I thought that may have been the reason this all started. The crank sensor couldn't consistently pick up the timing and confused everything things else. Now Part of me thinks that this violent shaking and stumbling may have been what broke the sprocket and allowed the key way for the sensor to get sloppy. So here I am. With the codes above showing. Could the ECM be bad? What else could be the issue?
  16. Risky1
    Visalia, CA
    Hi Mendel,
    This is not the 2006- its my sons 2010. and it technically is a continuation of a previous post from last year. sorry abouty that. EGY cooler and valve/solenoid have been replaced.
  17. Risky1
    Visalia, CA
    Yes! End of the World is correct!
  18. rjparker
    10,054
    6,220
    Other people have ended up with bent valves after a timing slip or an error installing it. I would do a compression check and borescope inspection.
    Brian1954 likes this.
  19. Risky1
    Visalia, CA
    would it sound like its idling fine in neutral/no load, if it had bent valves? possibly I guess it could. I will compression check.
  20. Risky1
    Visalia, CA
    It's running very well now. So. Summary... Something happened that caused the oil pump chain drive sprocket to break. This "something" was also severe enough to cause the crank sensor timing plate to widen at the keyway, and causing enough play that the crank sensor couldn't pick up and get correct time.
    I believe that this "something" was a severe misfire or multiple severe misfiring from issues with the head gaskets or EGR being clogged.
    or,
    It was caused by me, when I replaced the head gasket and placing too much torque on the crank bolt as these sprockets are all stacked on top of each other behind the crank balancer
    Anyway, the play in the sensor plate cause physical damage to the crank sensor, just slightly, that I didn't pick up on when inspecting it the first time.
    So I Replaced the crank and cam sensors, again..
    See the attached picks. You can see the keyway in the sensor plate all banged up and widened this cause considerable play in the sensor plate as it spun.
    tacopyro, Mendel Leisk and Mr. F like this.
