2023 Prius Ltd Awd MPG
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by rpT, May 29, 2023.
  1. rpT
    rpT Member
    39
    31
    new york
    2023 Prius
    Limited AWD-e
    seems very low. I’m getting like 43mpg. Driven it so far about 100 miles in mostly stop and go city traffic.
    Anyone else on the 19” awd getting relatively awful mileage?
  2. Trollbait
    12,505
    It is way too soon to expect the best fuel economy. In addition to the car getting 'broken in', you are still getting use to it. It might even be too soon for the computer to learn your driving pattern at this point.
    Something to keep in mind. The EPA tests are done on tires with the equivalent of 4000 miles on them, and the manufacturers would use even more worn ones if they could.
    That said check your tire pressures. Dealer could have set them too low, and slow leaks can happen.
  3. bisco
    51,841
    did you reset the meter after taking delivery?
    serious stop and go can be an impediment to good mpg's
  4. yarrh
    yarrh Junior Member
    17
    NYC
    2023 Prius
    Limited AWD-e
    I’m heavy footed and getting between high 30s and high 50s driving around NYC
  5. PhoS
    PhoS Active Member
    252
    204
    Nowhere
    2023 Prius
    Limited AWD-e
    I've been averaging around 47 combined pretty consistently. 2800mi on the car.
    samsprius1 likes this.
  6. Mendel Leisk
    41,318
    HacksawMark and daisy555 like this.
  7. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    **Link broken**
    70.9 MPG's on the 19's! Fuel-up matched the computer. Massive numbers on a barely broken in Prius with sports car wheels. I will be breaking all records on my new LE.
    **EDIT** I guess there's no way to link a Reddit thread on here? How dumb. Instead, Google: "2023 XLE 70.9 MPG for Entire Tank".
  8. planetarian
    planetarian Member
    75
    86
    Kentucky
    2023 Prius
    XLE AWD-e
    XLE AWD, driven 700 miles, mpg reading reset around 200 miles ago. Lots of hills in my very rural area which make maintaining high mpg rather difficult.
    Dips down towards 40-41 when I hit the parkway, with plenty more hills and higher speeds. If I stay local, I can maintain about 43, but I really have to try.
    On my old 2014 model, I think I was netting around 45. My '08 fusion gets around 30mpg as displayed in Torque.
  9. jpm8766
    jpm8766 New Member
    Northeast US
    2023 Prius
    Limited AWD-e
    Generally speaking, I haven't seen it below 45mpg for any trip greater than 5 miles. Some hills (but not mountainous), average speeds around 40-45mph, lifetime including break-in period mine is getting ~55mpg calculated from odometer and fuel pumps.
    Using the Eco-meter has helped me get consistent fuel economy, but even if I push well into the "power zone" I still generally get >45mpg.
  10. Mendel Leisk
    41,318
  11. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
  12. rpT
    rpT Member
    39
    31
    new york
    2023 Prius
    Limited AWD-e
    200 miles in, now averaging 48-50 mpg.
    daisy555 likes this.
  13. Mendel Leisk
    41,318
    Displayed or calculated:
  14. Hammersmith
    Hammersmith Senior Member
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Gen5 displayed mpg appears to be accurate. I've only filled up once so far, but it was dead on. Other users on here are reporting the same. I'll double check once or twice more to be certain, but if it stays as accurate as the first fill up, there won't be a point in calculating separately anymore.
  15. Hammersmith
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm up to 650 miles and I've reached 47mpg on this tank so far. Small town with lots of short trips. First tank was something like 43-45mpg, so it gets better as the car breaks in. I expect it to eventually reach low to mid 50s.
    daisy555 and Mendel Leisk like this.
  16. Mendel Leisk
    41,318
    That’s a refreshing change.
  17. Tom Lee
    Tom Lee New Member
    Minneapolis
    2023 Prius
    LE AWD-e
  18. Preebee
    867
    771
    Midwest
    2023 Prius
    Jeffnorton and reallyreal like this.
  19. planetarian
    planetarian Member
    75
    86
    Kentucky
    2023 Prius
    XLE AWD-e
    How tf? My XLE AWD gas mileage has actually gone down since I last commented. It's now sitting at 40.6 after around 1k miles, including a trip from kentucky to tennessee and back. I drive fairly conservatively, with basically no cargo, and AC on Auto set to 70 (in ~75-80F weather). Is it the AWD? Does the author of this article have no hills to contend with? They mention the Limited when comparing with official specs, but is that actually what they were driving? What's going on here?
    SpiderJJ likes this.
  20. rpT
    rpT Member
    39
    31
    new york
    2023 Prius
    Limited AWD-e
    lol yeah forreal, seems really high
