$325 to shut off my back up beeper?
Discussion in 'Gen 4 Prius Main Forum' started by chuckiechan, Jun 6, 2023.
  1. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I bought my 2020 Gen 4 used. This AM I called Toyota to see how big of a deal it was to shut of the totally annoying back up beeper. The person I talked to said they could only turn it down, not off and charged $325 ish to do it.
    Grrrr...
    Did I ask the wrong question or something.
    And car other non dealer service shops do this?
    Thanks in advance!
  2. Mendel Leisk
    38,247
    I think Dr Prius app will do it, at least reduce it to one beep.
    I like the back up beep, actually wish it was more to the point, say a voice saying “you’re in reverse”, over and over, but that’s another discussion.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    They can reduce it to one beep.
    You can do it yourself with an ODBII programer.
    You can use an old cellphone/tablet and a Bluetooth adapter. I use this.but it does much more than you need.
  4. bisco
    48,985
    LOL, stealers
  5. BiomedO1
    1,323
    723
    SacTown, Ca
    here you go: Dr. Prius & the 2021 Prime LE | PriusChat
    or PM me and we can do it in about 5 minutes.
  6. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I'll check into it. Is it possible to gank it and kill it?
    And is the 2020 the same as the '21?
  7. bisco
    48,985
    what does gank it mean?
  8. AzusaPrius
    AzusaPrius Senior Member
    1,673
    772
    Gank means to rip it off
  9. BiomedO1
    1,323
    723
    SacTown, Ca
    No; your just turning off an option on a menu.
    The car isn't running when this is done - only the computer is on.
    chuckiechan likes this.
  10. Animal Mother
    Animal Mother New Member
    Georgia
    Just buy the Dr. Prius app for your phone and a compatible ODBII scanner and use Dr. Prius to do it. Easily less than $50 and 10 mins of fiddling with the dongle and the app.
  11. BiomedO1
    1,323
    723
    SacTown, Ca
    I used the free version of Dr. Prius to do mine, way back then. The cost was only the Bluetooth OBDII dongle.
    If that helps
  12. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    I meant damage or destroy or otherwise cause a malfunction. Sorry about the jargon.
  13. GoodOldBob
    GoodOldBob Junior Member
    51
    Mena, AR
    2020 Prius
    L Eco
    I just ordered a OBD2 to Bluetooth dongle for $5 from AliExpress (China) ....when It arrives, I'll install DrPrius on my cellphone and shut off that beeping. (2020 Prius L Eco)
  14. chuckiechan
    chuckiechan Member
    172
    53
    Roseville
    2020 Prius
    A shop did it no charge. It was in a screen the BOE thing opened on the dash board display, rather than in the BOE innards. It also shut off the seat belt reminder.
    I was seriously getting "beep fatigue" as I backed out of my driveway. I learned to ignore them all
  15. bisco
    48,985
    nice, i'd love to get rid of the seatbelt warning
  16. sylvaing
    sylvaing Active Member
    859
    362
    I "rented" the Carista app for a month and adjusted some of the settings that the stealerships charges way too much to do.
