I like to read the consumption chart as an inverted altitude graph
Discussion in 'Gen 2 Prius Fuel Economy' started by Nelflez, Jun 8, 2023.
  1. Nelflez
    Nelflez New Member
    Colorado
    Kinda off topic but I do a lot of mountain driving and so I learned to read the consumption chart as if it's an altitude chart, where higher MPG represents a decline in altitude and vise versa lol. Disclaimer: (Doesn't work if you like to race down mountains)
  2. Nelflez
    Nelflez New Member
    Colorado
  3. fuzzy1
    10,044
    Excluding downhill glides, I get my best MPG on high altitude plains and plateaus. The air drag there is significantly less than at sea level, saving fuel. On traditional non-hybrids, the reduced engine pumping adds additional MPG improvement, though hybrids reclaim a good portion of this through other means (see "Atkinson-cycle engine') without getting to high altitude.
    The climb up to those high altitudes does have some MPG cost. The benefit doesn't show up until the road levels out.
    ydpplqbd likes this.
  4. Jafar G
    Jafar G New Member
    houston tx
    Hello, Did you find something on this, I second what you're looking for.
