How to change Maintenance reminder details
Discussion in 'Prime Main Forum (2017-2022)' started by David Gabel, Jun 8, 2023.
  1. David Gabel
    David Gabel Junior Member
    Victoria, BC
    2018 Prius Prime
    I have a 2018 Prius Prime. The maintenance reminder comes up as and when it should. The problem is I’ve moved and the dealer details are wrong. I’d like to change the reminder to the nearest dealers details. It was quite convenient to press the call button to set up the service appointment.
    anyone know how to update this info?
    52,341
    if you can't do it, perhaps the new dealer will do it as a courtesy, since they'll be getting your business
  3. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    Menu (5 circles) button on right side of display unit -> Settings -> Vehicle (on page 2) -> Maintenance -> Set Dealer
    bisco and David Gabel like this.
  4. David Gabel
    Victoria, BC
    2018 Prius Prime
  5. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    And, there is no need to go to the dealer for any work except a warranty claim. A good local shop can do the work that is needed and maintain the warranty coverage often for less money. Retain the work orders and receipts. Use your owner's manual to be sure all the needed jobs are listed on the work order. Or one can do the work themself...retain the receipts.
  6. road2cycle
    168
    109
    Sonoma County, CA
    One extra thing to add is on the maintenance menu you can also add reminders for services to either be DIY’ed or have performed by a dealer/mechanic shop. You can enter date and/or mileage until the specific service item needs to be performed.
