Maintenance Items
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Hammersmith, Apr 30, 2023.
  1. Hammersmith
    Hammersmith Senior Member
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Does anyone have quick access to the part numbers for maintenance items like oil filters, engine and cabin air filters, and wiper blades? Or know where to find them online?
    I'm replacing the door lock actuator on my 2010 in prep for trade(I already had the part, but didn't get it installed before winter hit) and found that the body shop that touched up my door last fall did a bit of a hack job to a couple delicate parts. I'm ready to order, but they're so cheap that the shipping costs are over 50% the cost of the parts. I get free shipping at $75, so I figured I'd fill out the order by pre-stocking on some 2023 supplies, but I don't know who to trust to get me the correct items.
    If nobody knows or gets back to me tonight, I'll just call a dealership in the morning, but I'd like to get the order in tonight so I don't forget or whatever.
    Thanks.
    2023p likes this.
  2. Ronnie5
    Ronnie5 Member
    49
    56
    2023 Prius
    Toyota dealer told me the oil filter is 90915-YZZN1
    rkalbo likes this.
  3. Hammersmith
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    LOL. That's filter they also used for the 2nd and 4th gen, but not the 3rd gen(which I have a spare for). Thanks.
  4. Hammersmith
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Okay, I've got some info, though a little of it is annoying at the moment.
    First, parts.toyota.com is now autoparts.toyota.com. Apparently that happened sometime in the last few hours, because it wasn't that way last night or even this morning. Somewhat redesigned website, but even less 2023 info. (Though it might explain why Toyota has been so slow updating the MY23 models if their department was working on getting the site change ready.) At the moment, it's only partially working. Some of the products below should be in the system, but I'm getting a 'no suggestions found' error.
    Oil Filter: 90915-YZZN1
    Engine Air Filter: 17801-24040
    Cabin Air Filter: 87139-YZZ83 (not sure if there's also a "Premium" version with activated charcoal like you've been able to get before)
    Wiper Inserts: 85214-0E130, 85214-08050 (not sure which is left and which is right)
    skirmish, daisy555 and Toymeister like this.
  5. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    90915-YZZN1 is also the one for my Venza, although autoparts.toyota.com tells me it's now 90915-10009. Weird, because 90915-YZZN1 is the original one I took off when I changed the oil at 5K.
    Edit: 90915-10009 was replaced by 90915-YZZN1.
    #5 RRxing, May 1, 2023
  6. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    Oh I think it’s the same filter I use on my 2019 RAV4 hybrid spin on.! I hate those paper elements! Have you decided what are dash cam you’re getting? I know there is a Toyota and Lexus only difference being red button versus black button! Or maybe you’ve gotten it already! Originally I thought it was a factory or port installed and my dealer said he’s going to check on the price sounds easy enough. I’ve done it before pretty handy. I like to do things myself then I know they’re done right! I am planning oil changes at 5K like I do everything else!
  7. Trollbait
    12,676
    The new site came up in the venting thread in the FHoP section.
  8. novak068
    novak068 Junior Member
    US
    Most likely not yet transferred all the positions to the new site. Now everything can be found in the search.
  9. Ansari
    Ansari Junior Member
    43
    2023 Prius
    Where Do I fond Battery air filter? I don't see around back seat. Any advise?
    sakozar likes this.
  10. Hammersmith
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Drivers side, rear seat, foot area. It's a little tough to see with everything being black on black, but it's super easy to feel the plastic grille. If you want to take it off, put your trim removal tool on the inside vertical edge and pull toward the door. The filter itself is mounted into the grille and can be detached for cleaning.
    Ansari likes this.
  11. Ansari
    43
    2023 Prius
    I bought the 2023 Prius on the first year. Did I made the right decision?
  12. bisco
    52,371
    i think so
  13. Doug McC
    Doug McC Senior Member
    1,081
    420
    Midwest
    2022 Prius
    Only time will tell, so just enjoy it.
    daisy555 and Ansari like this.
  14. Ansari
    43
    2023 Prius
    Does prius use 0w 8 engine oil?
  15. Ronnie5
    Ronnie5 Member
    49
    56
    2023 Prius
    No. It uses 0W-16.
    Ansari likes this.
  16. MaxT
    MaxT Junior Member
    27
    45
    Georgia
    2023 Prius
    The transmission calls for the new e-transaxle fluid TE.
    Went to dealership and they did not have it or know of it.
    Xse likes this.
  17. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    879
    Monument, Colorado USA
    I've, yet, to hear of any issues so signs are looking good....issues with the 2022 Tundra starting coming out within weeks of the release!!
  18. Hammersmith
    2,315
    2,363
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I've been putting this maintenance list together for my own use, but maybe some others might find it useful for themselves. The service intervals are absolutely on the conservative side, but they come from people I trust with significant real-world knowledge. But obviously feel free to change them to suit your priorities/needs. Mostly I've made it just to keep track of part numbers and amounts so I'm not re-searching for things every couple years.
    Code:
    Prius Maintenance Parts List
    Item                    P/N or type     Notes                   Frequency               Amount
    Oil                     0W-16           decent quality          6 month/5k miles/8k km  4.4qt/4.2L(HEV) or 4.1qt/3.9L(PHEV)
    Oil Filter              90915-YZZN1                             6 month/5k miles/8k km  1pc
    Engine Air Filter       17801-24040                             as needed               1pc
    Cabin Air Filter        87139-YZZ83     standard
    Cabin Air Filter        87139-76020     w/ activated charcoal   as needed               1pc
    Wiper Insert Driver     85214-08050                             6 month or as needed    1pc
    Wiper Insert Passenger  85214-0E130                             6 month or as needed    1pc
    Engine Coolant          00272-SLLC2     Super Long Life(Pink)   5 yrs/50k miles/80k km  6.4qt/6.1L
    Inverter Coolant        00272-SLLC2     Super Long Life(Pink)   5 yrs/50k miles/80k km  1.7qt/1.6L
    Spark Plugs             90919-01289     or NGK/Denso equiv.     120k miles/200k km      4pc
    Transmission Fluid      08886-02605     e-Transaxle Fluid TE    6y/60k miles/100k km    3.9qt/3.7L
    Brake Fluid             DOT3 or DOT4    get wherever(prob DOT3) 3y or >3% H2O           ~2pt
    Tires                   195/50 R19                              6y or <3/32" or <2.4mm  4pc
  19. MaxT
    MaxT Junior Member
    27
    45
    Georgia
    2023 Prius
    Let me know if you find the e-Transaxle Fluid TE. My local dealership is trying to locate it.
    model464 likes this.
  20. Ansari
    43
    2023 Prius
    Excellent work. I saved it for myself. I hope we won't see any issue since Prius is new design first year. How is your Prius running? Can we use AC during the engine break-in period or it's a load on engine?
