Engine air filter
Discussion in 'Gen 2 Prius Main Forum' started by GeorgeMW, Jun 7, 2023.
  1. GeorgeMW
    GeorgeMW Junior Member
    57
    Georgia
    Hello. I own a gen 2 Prius, and I have a couple questions.
    1) If the engine air filter is out of order, would that have any impact on MPG?
    2) I live in a city that has levels of air pollution likely 10% higher than normal due to building projects that are not being performed in compliance with standards. In these circumstances, how many miles to go before changing the engine air filter?
    I must say that the engine itself functions well. I thought low MPG would be the fault of spark plugs, but that does not seem to be the case.
    Thank you in advance for your attention.
  2. pasadena_commut
    pasadena_commut Senior Member
    2,806
    838
    Southern California
    Regarding air pollution, it depends what you mean. Most of the gas pollutants (NOx, CO, Ozone) will pass right through the filter. Some of the more reactive ones might chemically interact with it, but not in a way which is going to change its function measurably. On the other hand, if there is a lot of soot, dust, or even pollen in the air that will clog up the filter in short order. The worst of all worlds is embers, as when driving near a big fire. Embers can and do light the paper air filters on fire. This happens pretty frequently to the cops who have to go up and down the streets ordering people to evacuate as a fire closes in.
    Occasionally filters will clog up with leaves. This doesn't happen very often though. It needs some condition to put a lot of leaves up in the air while the car is driving through them. If it does occur that is one of the few instances where blowing out the filter and putting it back in might be warranted.
    Anyway, instead of worrying about it, just put in a new air filter. They are pretty cheap. Compare the old one to the new one at the swap and you can see how dirty it is, which generally, but not always, indicates how clogged up it is.
  3. bisco
    52,351
    There are a lot of things that can affect mpg’s on a Prius.
    Tell us more about your car and its history
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,086
    1,997
    NJ-USA
    Air filters are cheap. If it bothers you then just replace it. But it would have to be really dirty before it affected mpg's.
    Lots of things can affect mileage. Restricted exhaust, tire pressures, wheel alignment, HV battery condition, etc.
  5. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    Once a year take it out and hold up to a light. If there is crud in the crevices replace it.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Poor mileage in an old G2 is usually because the hybrid battery is on its last legs. You have to really give it the gas to get anywhere because the hybrid battery is not providing any power. Start watching the battery meter on the mfd.
    If the battery tanks to no blue bars or a purple bar its battery time. Its just the age. At 2007 its long overdue.
  7. Mendel Leisk
    41,865
    I’ve read a partially clogged air filter will improve mpg; it reduces air flow, the cars computers accordingly reduce fuel injected. You’ve essentially downsized the engine. Acceleration suffers a little.
    priumium likes this.
  8. GreenMeanie
    GreenMeanie Junior Member
    51
    If I'm replacing my air filter on my 2006 Prius, do I need to get a genuine Toyota one? Or is there an aftermarket brand that will do?
  9. BiomedO1
    4,090
    2,140
    SacTown, Ca
    save a few bucks, aftermarket will be fine....
  10. Mendel Leisk
    41,865
    For something you change every 5 years or so, not worth the gamble. I’m thus for anything significant, say brake pads for example.
  11. GreenMeanie
    51
    Ok,thanks guys.
  12. pasadena_commut
    2,806
    838
    Southern California
    You would think, right? But last time I looked it was actually cheaper at a dealer than any place local where I could drop in and buy one - if they even had one at all. Let's see...
    17801-21040 is the OEM part number. Manufacturer's list is $30.99 but local dealers are often much less, and sometimes there are specials. Current price at Puente Hills Toyota is $20.39. RockAuto has the Denso filter for $12.32, and some others from WIX etc for similar prices, but they would cost more than the dealer if it was the only item ordered, once the shipping was figured in. Walmart carries a Fram filter but it is out of stock at the closest store. If it was in stock it would have been $12.27. Autozone has an STP for $22 in stock. O'Reillys has a Microgard in stock, again for $22.
    RockAuto usually works out cheapest if the purchase includes several items (preferably from the same warehouse) and one can wait a few days to receive it. Otherwise, some dealers actually do have competitive prices for parts like this.
  13. BiomedO1
    4,090
    2,140
    SacTown, Ca
    Congratulations; you've found more expensive non-OEM alternatives - Caveat Emptor - Let the buyer beware.........
    Someone needs to pay for marketing, advertisement, and convenience.
  14. ETC(SS)
    7,334
    https://assets.sia.toyota.com/publications/en/omms-s/07ToyMS_MS0003/pdf/07ToyMS_MS0003.pdf?_gl=1*ks1czm*_tmna_au*MzIyMjk0NzUyLjE3NjYxODU0NDI.*_tmna_ga*OTQyNjcxMTM0LjE3NjYxODU0NDI.*_tmna_ga_EP43E5EFVZ*czE3NjYxODU0NDEkbzEkZzEkdDE3NjYxODU0OTgkajMkbDAkaDA.
    The Warranty and maintenance guide says to replace the engine air filter every 30k, IIRC.
    I usually change mine about every 12-15k with a good quality aftermarket or OEM filter.
    Toyota doesn't build air filters, and they haven't built your generation of Priuses in nearly 20 years - so there's about a 100-percent chance that whatever filter you get in the box from the mothership was made by the same plant that makes most of the aftermarket filters.
    Don't.....DO NOT.....NEVER-EVER......be tempted to use one of those goofy 'performance' air filters that you clean, oil, and re-use.
    BiomedO1 and frodoz737 like this.
  15. GreenMeanie
    51
    Got it. Thank you all.
  16. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    marketing, advertisement, and marketing, advertisement, and conveniencemarketing, advertisement, and convenience, marketing, advertisement, and convenience.
    This is management/imaginary values you should not pay for on the interwebz.
  17. qmanqman
    qmanqman Active Member
    439
    152
    CO
    They basically keep out rocks, bugs, and leaves. You don't need to spend money on an air filter. My neighbor has a 72 Chevy van and all he does is bang the filter on the ground to knock out all the debris and then put it back in. I think his filter is 20 years old.
  18. pasadena_commut
    2,806
    838
    Southern California
    The engine air filter is not just a barrier for macroscopic objects. That van is probably losing at least a couple of MPG because it has to suck air through a filter completely packed up with small particles.
    Brian1954 likes this.
