Gen3 Prius engine noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Elvis Frederick, Jun 11, 2023.
  1. Elvis Frederick
    Elvis Frederick Junior Member
    New jersey
    While I was on the highway I suddenly heard a strange engine clink clink clack clack. So I pulled over and had the car towed to my home. I have since since cleaned EGR and throttle body but the sound remains. Any I deas
    ukulelegeek likes this.
  2. JC91006
    JC91006 Senior Member
    16,825
    8,600
    were you low on oil?
  3. Mendel Leisk
    41,850
    What’s the miles?
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    coolant level?
  5. bisco
    52,335
    what year?
  6. Elvis Frederick
    New jersey
    No, I just change my oil at Toyota. Toyota used Tech stream, but no codes showed up. According to the Toyota technicians, the clink clank suggested that something let go in the engine. Their diagnosis was rather vague. Also, I changed my head gasket in December.
  7. Elvis Frederick
    New jersey
    213000 miles, I keep up with my oil maintenance
    ukulelegeek and Mendel Leisk like this.
  8. Elvis Frederick
    New jersey
    Filled, It is not losing coolant. Also, it has a new water pump. After the strange song the car lost power.
  9. Elvis Frederick
    New jersey
    2010, Prius
  10. Brucetafer
    Brucetafer Member
    126
    60
    Orlando Florida
    get a cheap coolant pressure / vacuum tester.. run the engine and you'll see pretty quick if theres headgasket or crack..
  11. Brucetafer
    Brucetafer Member
    126
    60
    Orlando Florida
    also check your timing, my 2007 had a timing chain get lazy and maxed out the tensioner, sounded like all the lifters were playing a techno song
  12. Brucetafer
    Brucetafer Member
    126
    60
    Orlando Florida
    also, make sure your valve cover gaskets are good and the cover is clean, my shower port was clogged pretty bad at 141k miles and was not flowing sweet dinosaur juice to the cams..
  13. Elvis Frederick
    New jersey
    The head gasket was already replaced. The timing was checked, tensioner replace.I am suspecting rod bearing or VVTI Gear. I will love to post a short video, with the sound, but since I am new, I cannot.
    #13 Elvis Frederick, Jun 17, 2023
  14. Mendel Leisk
    41,850
    At what miles was head gasket replaced?
    At what miles was EGR and throttle body cleaned? Was that the first cleaning? Was the intake manifold (with its EGR passages) cleaned as well? How thorough was this cleaning; you did it yourself?
  15. ukulelegeek
    ukulelegeek Active Member
    159
    112
    Mine just did a clatter and shudder thing, no dashboard lights, no warning. Lost power quickly. Oil, fine, coolant, fine. No power to drive it at all. What do you think it could be?
  16. bisco
    52,335
    bad gas?
  17. ukulelegeek
    159
    112
    Nope, I wish. Coil(s) wore out. She's getting new coil(s) and spark plugs. About $740! This car is NOT cheap to drive, but it is 13 years old. I really hope I'm done with repairs for a while.
  18. bisco
    52,335
    wow, not sure i've ever heard of that before, but it makes sense i guess
  19. JC91006
    16,825
    8,600
    I hope the diagnosis is correct......
    Mendel Leisk and ukulelegeek like this.
  20. Priipriii
    Priipriii Member
    230
    67
    I got 4 working coils off the junkyard for like $15 each. Where are you buying that it ended up being $740??? Thats crazy lol
