  1. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Shocked that you didn’t schedule your Prius to be repainted with the blizzard white pearl customer thingy without any charges
  2. brzy25
    brzy25 Junior Member
    40
    30
    What do you mean? Was there a blizzard pearl recall on the Prius's too? I know the Sequoia and the Lexus suv's had some but I never had any paint problems other than the road cone splitting my bumper wide open. I should have taken a pic of it before, the fog light was knocked loose and the bumper was sticking out from the fender.
    Edit - Did a google, found it. None of my paint ever peeled, though I do have a ton of tiny rock chips I've touch up painted to stop from spreading.
    #19202 brzy25, May 14, 2023
  3. Matth Torrijos
    Matth Torrijos Active Member
    114
    207
    Poway
  4. Fifen
    Fifen Member
    77
    32
    Utah
    Is there a recall for the Blizzard Pearl paint? I couldn't find anything. But my clear coat is peeling in spots and the top of the car has a yellow hue to it.
  5. Fifen
    Fifen Member
    77
    32
    Utah
    Could you share what Amazon products you bought? I have a lot of spots I need to touch up. rust and other damage.
  6. douglasjre
    douglasjre Senior Member
    1,877
    653
    Orlando, FL
    No recall but the bone white PPG paint is known to peel on Toyotas and Hyundai's. You have the pearl white so you'll have to do a little investigation
  7. ukulelegeek
    ukulelegeek Active Member
    156
    104
    It looks good to me!
  8. ukulelegeek
    156
    104
    No need to use Amazon. I bought my kit directly from AutomotiveTouchup.
  9. Matth Torrijos
    114
    207
    Poway
    IMG_8217.jpeg Re clear coated fender. Hopefully the paint matches with the car
  10. Matth Torrijos
    114
    207
    Poway
    IMG_8294.jpeg Finally done painting
    djschwin00, w84me, FST4WHT and 5 others like this.
  11. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    Looks like you nailed it!
    Matth Torrijos and Ryan Will like this.
  12. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    Your Prius looks sick!!!
    I hope to see it roaming around sometime... I do work in Poway from time to time.
    Matth Torrijos likes this.
  13. Montgomery
    2,254
    2,238
    Orange County, CA
    The Gen III allows for so much custom modification, both inside and out.
    Xterra72 and Matth Torrijos like this.
  14. Matth Torrijos
    114
    207
    Poway
    I still have to finish blending and fixing some parts of the clear coat but i have to wait until the paint is cured
    Montgomery likes this.
  15. Matth Torrijos
    114
    207
    Poway
    Thanks man! I used to live in poway buy walmart then moved up to vista. I drive a lot in 78 and 5 freeway now
  16. Ryan Will
    Ryan Will Member
    68
    43
    Southern California
    Yup, very familiar with that area as well! I’m sure I’ll see you driving around one of these days!
  17. FST4WHT
    FST4WHT Junior Member
    Sacramento, CA
    20230614_084603.jpg 20230614_084551.jpg 20230610_204446.jpg Still a lot of work that needs to be done but finally on bags!
    w84me, ukulelegeek, ockevin and 5 others like this.
  18. Montgomery
    2,254
    2,238
    Orange County, CA
    When you park your car, this makes it much harder for someone to steal your Cat. Plus, it just looks so cool!
    ukulelegeek, SubCode, FST4WHT and 2 others like this.
  19. Coots
    Coots Junior Member
    61
    Hailing from parts unknown, Iowa
    The ONLY braces I trust are OEM and Tom's.
    I trust that if Toyota adds these, they certainly do something.
    It's been my experience in the past with my Hondas, that some of the Tanabe bars are tubular aluminum that can flex when pushed upon, even before installation. I can't comment on all of the Cusco bars. I do have one of their front upper strut bars on my CRX and that's a solid piece.
    The G's rear brace noticeably tightened the rear end up a bit. Along with the TRD rear sway bar. The front strut bar did tighten things up, too. How much is debatable, but it was noticeable to me, especially in a 13 year old car. The front strut bar was the first one I did.
    One brace alone may not make too noticeable of a difference, but coupled together they can.
    I have not added the rest of the braces, yet.
    The Tom's and G's rear brace are basically the same thing except Tom's is a single welded piece.
    Tom's is discontinued.
    You can do the Lexus / Scion front lower brace:
    Front T-Brace
    Front lower X-brace
    The Tom's lower front brace is discontinued:
    Side subframe reinforcement
  20. Coots
    Coots Junior Member
    61
    @Priipriii That looks really nice! What head unit is that?
