Gen 1 No Air Circulation in Cabin
Discussion in 'Generation 1 Prius Discussion' started by tr_blankenship, Jun 15, 2023.
  1. tr_blankenship
    tr_blankenship Junior Member
    I tried searching but couldn't find any other posts or solutions. Could be my verbiage, who knows.
    Anywho, my 2001 already had A/C issues - where it works great for a few minutes then the light starts flashing and the air is no longer cold. Found the solution for that and have in hand the little washers to replace. BUT this week it not will no longer blow any air in the cabin - hot, cold, no air at all. I've tried all of the different settings and still nada. Anyone experience this and have a fix?
    Cheers - Tam
    Over 350,000 miles and still love her!
  2. Brock Turner
    Brock Turner Junior Member
    St. Paul, Minnesota
    2002 Prius
    My 2002 did this the other day. All I did was hit under the glove box, and the fan started blowing again. I'm not sure if the fins had a minor obstruction or if the plug just barely came undone... I've had this same issue on our 09 Corolla and 98 Camry, each time merely hitting the fan fixed it.
    If that doesn't work, it's time to check fuses, wiring to the switch and to the fan motor, or the fan motor itself.
    Good Luck!
    tr_blankenship likes this.
  3. Trombone
    Trombone Active Member
    331
    113
    Allentown, Pennsylvania
    2002 Prius
    The blower fan is located behind the glove box, and is quite visible when you remove the cabin air filter. Have you checked the fuse? See owner's Manual for fuse location.
