New Owners Second Key Fob
Discussion in 'Gen 4 Prius Main Forum' started by ocean view, Jan 24, 2023.
  1. ocean view
    ocean view Junior Member
    31
    Western MA
    2022 Prius
    That second fob was issued by the dealer not Toyota.
  2. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    Your 2021 did come with 2 when new. It's been pretty standard new cars come with 2 keys for as long as I can remember. It's not uncommon that 1 is MIA by the time folks trade in years later. My first Prius was used and they only had 1 key. It turned it bad for me when I drove an hour to work in the pickup with it in my bag only for the wife to call my furious that she couldn't leave for work. I had to drive home again defeating the whole purpose of switching cars that day because she had a longer drive. We got another fob soon after and made sure the next used car we got had both keys before buying it
    Since last year many new Toyotas and Lexuses are being delivered with only 1 fob from the factory and a promise to eventually get you the 2nd one.
  3. ocean view
    31
    Western MA
    2022 Prius
    Here's an update.
    Things are starting to happen.
  4. bisco
    51,413
    wow, they had to make a video of what a sentence or two would have sufficed?
  5. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
  6. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    ATTENTION!!!
    Check your Toyota app
    Received today…
  7. jdenenberg
    jdenenberg EE Professor
    3,929
    1,929
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Driving a modern car with only one FOB is a bad idea. If you lose that FOB, it is very expensive to get your car running again as the dealer will have to replace both the FOB and the relevant ECU. This became obvious to me when I was at the Subaru dealer for regular maintenance when they misplaced our FOB. After they tried unsuccessfully to program a new FOB several times, my wife had to drive down with our second FOB so that they could complete the programming of the new FOB. The good news is that we later found where the dealer had misfiled the original FOB and now we have 3 FOBs for our Subaru (and the new FOB was free).
    JeffD
  8. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    Just called local dealership, they confirmed the service bulletin & parts available.
    Scheduled appnt for next week
  9. avocadoman1
    avocadoman1 Member
    217
    36
    Fallbrook-CA
    2022 Prius
    It’s done!
    FINALLY!
    Got the 2nd KeyFOB today.
    Purchased a ‘22 Prius Hybrid on 1/15/2023 and received just the one FOB.
    After receiving service bulletin notice via Toyota app 11 days ago…made appnt with dealer.
    So that part went smoothly after waiting for 5.5 months.
    I also asked for an oil change with only 4,000 miles on the odometer. But policy is “it’s 10k miles or 12mo” for the free service. No exceptions!
    So I’ll get 2 oil changes in 24mo of ownership.
    Instead of an oil change they rotated tires and checked fluids.
  10. nagrath
    nagrath Member
    142
    47
    Putnam County, New York
    2023 Prius Prime
    XSE
    Purchased my Prius Prime in early July, still have not received any notice that my second fob is available. Gotta say, this was a BAD idea. I understand why they were opting to do this because of the chip shortage, but perhaps a better solution could have been found (for example, one of these companies that make aftermarket fobs!).
  11. TractionAction
    TractionAction Junior Member
    Brentwood CA
    2024 Prius
    To fob or not to fob. Anyway, I use my smart phone as a key and remote start etc. Bought my 2024 a month ago and good to hear we'll eventually get a 2nd fob..
  12. jdenenberg
    3,929
    1,929
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Just don't lose the single fob. In the past, you needed an old fob to program a new fob. Your only other option was to buy a ne ECU $$$$.
    JeffD
  13. dbstoo
    dbstoo Senior Member
    1,383
    748
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    My car is a 2024 Prius Prime, purchased mid January 2024. It came with one key fob and I was told that a replacement was available. The VIN was not registered on the Second Key Delivery Plan database until April/May.
    I received the new second fob 2 weeks ago. Works as advertised.
    NOTE: I was told that I could use my cell phone as the second key fob using the digital key feature. That worked reliably IF I turned off my WiFi as I approached the car so that it would use the Blue tooth signal.
