Emergency internal hatch release procedure
Discussion in 'Gen 5 Prius Main Forum' started by SupersonicPrius, Jun 16, 2023.
  1. SupersonicPrius
    SupersonicPrius Junior Member
    39
    55
    Colorado
    2023 Prius
    I reviewed the extremely comprehensive owners manual and unfortunately didn't find the procedure to release the rear hatch from the inside of the vehicle in an emergency like the 12v battery being discharged. I popped the small plastic rectangular cover on the inside trim of the hatch where the latch is, but I didn't see or feel a release. I also removed the foam liner under the cargo cover and didn't see a release there either. Has anyone determined the procedure yet for a 5th gen Prius? As a side note, mine is an XLE so no power hatch.
    mountaineer likes this.
  2. ChapmanF
    18,501
    There seems to be a cover that you turn first. See pages 121 and 122 of that owners' manual.
    SupersonicPrius likes this.
  3. bisco
    52,351
    Why do they have to make it so difficult?
  4. ChapmanF
    18,501
    There was probably one incident where somebody dropped a peanut behind the hatch deck and it somehow got under the release lever.
  5. bisco
    52,351
    or a really smart canine popped it and fell out the back
  6. SupersonicPrius
    39
    55
    Colorado
    2023 Prius
    Thanks for that and agreed it's in the manual but hard to find since they call that the "back door". Guessing it's for legal reasons which is annoying!
  7. Trollbait
    12,665
    If they called it a hatch in the manual, they couldn't then call it a sedan on the window sticker.
  8. ChapmanF
    18,501
    I du᠎nno, sometimes it's just how things get translated from Japanese. I saw the only sections there were "side doors" and "back door" and there wasn't one for "hatch", and kind of thought "well, 'back door' might be it".
  9. CruisnGrrl
    CruisnGrrl Active Member
    149
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    So we should keep a screwdriver in the car.
  10. Hammersmith
    Hammersmith Senior Member
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, I think it's a combination of translation and also standardization of terms across models.
    Look at the FJ Cruiser vs. 4Runner. They both have rear openings of about the same size. But the FJ Cruiser has one that opens like a standard door, while the 4Runner has one that opens like a hatchback. Does Toyota use two different terms in all of their literature for effectively the same object, or do they just use a single term and not care about the trivial differences between them?
    For Toyota, the answer is the latter. If it opens and closes, it's a door. If it opens into the back of the main cabin, it's a back door. If it opens into a dedicated luggage compartment(trunk), it's not a trunk lid, it's a luggage compartment door. It's a little weird to wrap your head around at first, but when you consider the huge range of vehicles between Toyota, Lexus and Scion, it makes sense.
  11. ChapmanF
    18,501
    My first car had a whole little tool kit that came with it, in a roll-up pouch with the manufacturer logo.
    I still think that's good to have, even though I have to supply it myself now. (Some of the tools came from that original car and pouch!)
    I would consider a screwdriver to be a bare minimum to have on hand in the car. :)
  12. bisco
    52,351
    and a working flashlight
  13. SupersonicPrius
    39
    55
    Colorado
    2023 Prius
    In my view, anything called a door should be able to open from the inside and the outside, so calling the hatchback opening a door seems misleading (the temporary plate on the Prius calls the vehicle type “hatchback” as a side note). Since 2001, the government has required all vehicles to have an emergency release inside the “trunk” to avoid kids and people getting stuck or kidnapped. I am sure the way around this is if the trunk space is open to the rest of the cabin like this hatchback style or an SUV, but it definitely would be nice to have them regardless.
    I sleep inside the Land Cruiser on a platform when camping, and I added a JDM switch that allows the rear liftgate to open from inside the vehicle. I’m going to see if there’s a way to add the same switch to the Prius by tapping into the existing hatch release wiring. I plan to use the Prius in a similar way and camp in the back which is why I want to be able to open it without crawling through the second row doors.
  14. Paul Gregory
    Paul Gregory Senior Member
    2,227
    592
    Alberta
    2024 Prius Prime
    XSE
    This procedure is no good for me; I am incapable of crawling into the back.
    I talked to one parts man and he said there was a dash release button available, and he said it was $260.
    I have not been able to find any reference to it since. Was he wrong, or am I hallucinating?
    UPDATE: The hatch release button is an option on some levels of trim.
    The question is whether it can be retrofitted.
    #14 Paul Gregory, Nov 11, 2025
  15. ChapmanF
    18,501
    I worked out easily enough, from the wiring diagram, how to retrofit a dash release button in a model where it was never an option. Pretty straightforward.
    But that's an electric button, which wouldn't serve the use case for the OP in this thread.
    Are you able to determine whether the option that's offered on some levels is electric, or some actual mechanical remote release? I'm sure something could be rigged up with a Bowden cable, but unless the available option is clearly described that way, I'd assume it's more likely electric.
  16. rjparker
    10,457
    6,560
    You carry a lithium jump box in an accessible spot like behind the v's reclining rear seats. You use your manual key to get in the car, open the hood and supply power to operate the hatch.
    Others have rigged cables to the mechanism but that requires a complete disassembly of the hatch and some MacGyver rigging.
  17. Hammersmith
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    ^^This is the correct answer. Trying to rig a dash button for a gen5 with a manual hatch just so you can open it after a power failure is.... well, I can't come up with a polite version of what I think of the idea. Just leave a jump pack in the center console or glove box and call it a day. I've had to use one for that a couple times and it works just fine.
    BTW, this was a two and a half year old thread that just got necroed.
    futurist likes this.
