Prius Stolen without a key??
Discussion in 'Gen 2 Prius Main Forum' started by Miguel Olivares, Jun 18, 2023.
Tags:
  1. Miguel Olivares
    Miguel Olivares Junior Member
    56
    Oakland
    hey all.
    my girlfriends 2007 toyota prius with wireless key entry was stolen.
    there is only one set of keys for the vehicle. the key/fob was like 40 miles away.
    the car was locked..
    how is this possible?
    how did they manage to take it even though the key/fob was cities away?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Grabbed it with a tow truck takes literally about 20 seconds.
  3. Miguel Olivares
    56
    Oakland
    doubt it,
    they took it for a spin, stole packages and left it in the middle intersection before the city police towed it to the yard and charged us 800$
  4. BiomedO1
    4,118
    2,164
    SacTown, Ca
    I gather this was a used Prius, 2nd or 3nd owner. The original FOB or old programmed FOB was never erased from the car. If there's no damage to the steering column or OBD connectors; that's how it was done.
    Replace and reprogram a spare FOB and have the tech erase any remaining programed FOB from your car.
    Hope this help.....
    PS. FOBs needs to be keep at least 20 feet from your car, in a enclosed metal box, refrigerator, or Faraday bag. This will cut-off the FOB signal and prevent hackers from emulating the signal. Once the car is started, it will run without the FOB nearby. This prevents the car from shutting-down because of a weak FOB battery, on the interstate (safety issue).
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    RFID chip type immobilizer systems have been around for 20 years. I'm sure that by now you can get some kind of widget from China that can "spoof" the system and let anyone turn the car on.
    Any security tech that's been made can be analyzed and defeated.
  6. highmilesgarage
    highmilesgarage Active Member
    493
    182
    Kansas City
    could be owner error too, left it running, forgot to turn the power off. Doesn't need the key present to drive away.
    Goodcitizen and edthefox5 like this.
  7. edthefox5
    10,096
    4,834
    Clearwater, Florida
    For what reason why would the original fob ever need to be erased? Are you saying the original owner came and stole the car with a spare fob he kept?
    And if someone has the smarts to emulate a code I doubt there going to waste there time on an old Prius then leave it in the middle of an intersection.
  8. Aegean
    Aegean Active Member
    464
    208
    Alexandria VA
    I suspect that they targeted the car days before the day they stole it and used it to steal delivered packages, or anything else like stealing catalytic converters, wheels and tires or carry drugs.
    Did you girlfriend leave the car recently for an oil change or other service? One dishonest employee might performed the chicken dance with a new blank keyfob using your girlfriend’s only key when she left it with the store. Then they just waited for the right time to use the new keyfob.
  9. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    The FOB/lock is not actually a one-time-pad, so it's hackable using things like Replay Attacks, regardless of if the FOB is nearby. When the cars were originally built the equipment for this would be super expensive and require special knowledge, so it wasn't that common. but now you can buy a cheap SDR (Software defined radio) usb dongle and plug it into your laptop
    There are tons of articles about this, here's some good intro
    Toyota has some pretty laxed security standards... - SDR - Software Defined Radio - Hak5 Forums
    Radio Attack Lets Hackers Steal 24 Different Car Models | WIRED
  10. Mendel Leisk
    41,893
    If it’s a wash, comparing the security of an old-school ignition key with an electronic fob, maybe time to go back, if only so you don’t need to pay $100’s for lost/missing or went-through-the-wash fobs?
    The gen 5’s are apparently only coming with one fob too, with another one to be available “sometime down the road”.
    what’s the manufacturers main reason for going with fobs? As always, I suspect $’s.
    Standard car key vs. keyless entry: Which can better secure your car?
  11. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    Nice article, thanks for posting!
