Reset ECU after replacing hv
Discussion in 'Gen 2 Prius Main Forum' started by Ernie stires, Jun 22, 2023.
  1. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    Should I reset the ECU after installing a rebuilt HV battery?
  2. highmilesgarage
    highmilesgarage Active Member
    485
    178
    Kansas City
    no such thing, if you're refer to clearing the codes present then yes but you don't have to since it will clear itself (if no issues). Disconnecting the battery alone clears the ECM (engine side only) codes.
    Ernie stires likes this.
  3. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    Thanks. Would it be normal for the ICE to run more initially? I haven’t driven it except around the block and dr prius reports all pretty much good
  4. rjparker
    10,302
    6,445
    It might if the hv battery charge is depleted. Normally it would not run for more than a minute to add a little charge. If it does not normalize quickly after one ten minute drive (eg no engine at stop lights w ac on) then I would question the quality of the used battery.
  5. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    just did a 45 minute test drive and you are correct. The ICE settled down. Thanks! I don’t expect this battery to last more than a year, although I have a 3 year guarantee and I’m going to start sourcing a new Toyota battery.
  6. bisco
    52,136
    which company did you go with?
  7. PriusCamper
    PriusCamper Senior Member
    12,913
    5,240
    Pacific Northwest, USA
    Yep... It's not certain of charge level yet and is trying to get more data.
  8. Ernie stires
    Ernie stires Member
    107
    30
    Colorado
    I live in Denver and used Aplushybrid. Frankly I was stuck, the old battery chapped out-4 year old rebuild- and I needed mobile install.
