2011 with P0A80 code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius 49, Jun 24, 2023.
  1. Prius 49
    Prius 49 Junior Member
    Tucson, Az
    Arizona Prius, 150k miles. Per O'Reilly's Scan Tool this code came up. Dash indicators show engine problem and the large yellow triangle with Exlamation Mark in the middle.
    Seems like 150k miles is a bit early for the Hybrid battery to fail. Thoughts?
  2. JC91006
    JC91006 Senior Member
    16,827
    8,600
    It's normal to have a battery fail around the 10 year mark, you have surpassed that already
  3. Tombukt2
    13,408
    2,415
    Quite normal . And in AZ heat too.
    Brian1954 likes this.
  4. Prius 49
    Tucson, Az
    Thank you! Local Toyota quoting $7k for replacement. Realistic?
  5. Tombukt2
    13,408
    2,415
    No that's not realistic The battery mid pandemic for me was $1,464 I believe it was from the Toyota dealer brand new with my trade in which was a Toyota factory trade-in not an aftermarket green colored case none of that nonsense. Recently I guess I've seen their up to about $2,200 or so? I'd have to go literally look and then that would leave $4,600 or so for the installation boy I'd love to have that job No I would run from that I did buy my Toyota battery from Toyota online in my state and got the online price and picked it up at the dealer that's how you have to get the price the lowest price is buy it online through your local Toyota dealer but online pick it up at the dealership that's closest to you or where you are regularly or whatever and then when you're trade-in goes through they'll knock that off and in my case I wound up paying what I stated above.
  6. Brian1954
    Brian1954 Senior Member
    2,403
    962
    South Central PA, USA
    $7k is very high. Call around to other Toyota dealerships and ask for quotations.
  7. JC91006
    16,827
    8,600
    Call Steve from phoenixhybridbatteries.com he can get you the same Toyota OEM battery for about half the price you got quoted
  8. Prius 49
    Tucson, Az
    Thank you !!! :)
