?? Height of open hatchback??
Discussion in 'Gen 5 Prius Main Forum' started by Jack Lindsay, Jun 24, 2023.
  1. Jack Lindsay
    Jack Lindsay New Member
    2023 Prius
    Will be getting my new Prius LE next month, and I'm wondering about my garage door clearance. Can anyone please tell me the maximum height with the hatchback all the way open? Thanks!
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
  3. Perpetual Waffle
    96
    120
    Wisconsin
    2023 Prius
    XLE AWD-e
    It’s about 84-85 inches, by my rough measurement.
  4. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    Not much help for the original poster, but for the power hatch door on the Prius Limited, you have a choice of 5 heights for opening the door. I haven't measured the heights, but setting 1 hardly opens it at all, making it hard to use the close buttons on the door.
  5. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    How can you choose / select which height setting you want?
  6. KMO
    KMO Senior Member
    2,004
    729
    Finland
    2023 Prius Prime
    There are preset heights from the dashboard menu (Vehicle Settings -> PBD).
    Or you can set a custom position. From the manual:
    1. Stop the back door in the desirable position. [By pressing the open/close button while it's moving - if it's stopped in mid position like that, then short press continues to open, long press starts to close]
    2. Press and hold the open/close switch on the lower part of the back door for approximately 2 seconds
    When the settings are completed, the buzzer sounds 4 times.
    When opening the back door the next time, the back door will stop at that position.​
    pokenoprius likes this.
  7. pokenoprius
    pokenoprius Member
    51
    27
    New Zealand
    2018 Nissan LEAF
    Thank you
