Can The U.S. Power Grid Handle The EV Boom?
Discussion in 'EV (Electric Vehicle) Discussion' started by bwilson4web, Jul 1, 2023.
  1. bwilson4web
    16,182
    Source:
    I have a lot of problems with this video:
    • Cherry picked non-authorative, negative sources.
    • Didn't realize their own sections destroyed the bias.
    • Annoying 'Karen' voiced presenter.
    douglasjre, Rmay635703 and bisco like this.
    51,820
    i haven't seen any issues so far. i suppose that if the powers that be continue to ignore the grid, there will be future problems with or without ev's.
    but everyone needs a whipping boy as an excuse for their behavior
    bwilson4web, Rmay635703 and Trollbait like this.
  3. Doug McC
    Doug McC Senior Member
    1,078
    414
    Midwest
    2022 Prius
    Well, the power grid in Texas probably can’t, but then again, it can’t handle cold weather, can’t handle hot weather, either!
    As far as the rest of the country? Shoot, it isn’t anything they have to worry about with our current political situation in which no party wants to admit the need to switch from fossil fuel to EV technology anytime soon. At least not in any real way.
    just ignore this post, it is just my frustration with the whole political situation in this country. Sorry about that.
    #3 Doug McC, Jul 1, 2023
  4. Prius Maximus
    Prius Maximus Senior Member
    955
    810
    Northeastern IL
    Well, there won't be as much need for electricity to pump gasoline!
  5. Rmay635703
    Rmay635703 Senior Member
    2,665
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    I just saw this as well and despite being a typical so called liberal media outlet seemed to parrot off the same tired worst case scenarios that exaggerate I’ve seen coming from Republicans for years.
    bwilson4web likes this.
  6. Trollbait
    12,495
    Can't pump gas if the grid goes down from high AC use.
  7. ETC(SS)
    7,131
    Sooner or later, the power grid will HAVE to 'handle' the EV boom.
    There will be some bumps along the way but there's a lot of bucks at stake.
    I've often imagined out loud that there will someday be a smart-grid consisting of an intelligent source-load balance among the many BEV batteries, PV banks, and other 'sources.'
    That's right.
    BEVs plugged into the grid can be both a load AND a source... ;)
    Dot.gov just needs to lay down some streamlined regulatory guard-rails and get the hell out of the way.
  8. bwilson4web
    16,182
    Time of day pricing solves the problem.
    Guess that 16 kW, natural gas fueled, automatic, emergency generator installed in 2016 was a good idea. I don't care for the two-cylinder, air cooled engine but natural gas powered, fuel cells are a promise not a product.
    #8 bwilson4web, Jul 2, 2023
    douglasjre likes this.
  9. douglasjre
    douglasjre Senior Member
    2,161
    714
    Null, NL
    Already there
  10. Prius Maximus
    955
    810
    Northeastern IL
    Guess I should have put something like this in my post...
    ;) :D :LOL: :ROFLMAO: :whistle:
  11. ETC(SS)
    7,131
    NATGAS is a damn good solution, and I think that LNG tankers (barely portable nuclear weapon simulators) should be outlawed in the US unless they arrive empty.
    The US does NG cleaner, more efficiently, and with less corruption than most if not all the other producers.
    Stifling our capacity forces demand to be met elsewhere - less efficiently.
    Climate is GLOBAL.
    My hurricane genset is still portable and manual, but it IS a dual-fuel - although I would only use petrol if I were forced to.
    My intentions are to dry-pour a slab, and install a rain shelter and wire a manual interlock - which will also make my house grid-tie solar compatible.
    This way I can do the cost-benefit analysis if the genset goes TANGO-UNIFORM, and assess some DIY solar in the near future.
    The last hurricane taught me that I can get by with about 5kw.
    I'm going to double that and keep it portable and scalable.
    I also intend to outfit my garage for B(PH)EV charging as a land-grab.
    Someday the government will stop paying people to drive BEVs and start taxing them.
    THAT's when they will start being more obviously real-world affordable to the 99-percenters who are not EVangelists.
    When that happens I will start driving the droid version perhaps, or at least a PHEV.
    TWO sources are almost always better than one. ;)
    #11 ETC(SS), Jul 2, 2023
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Here's a little more realistic video.
    And, so far, my solar panels are keeping up with my Bolt EUV just fine. Here's the first six months:
    #12 jerrymildred, Jul 2, 2023
    CR94 likes this.
