Hybrid Pit Stop
Discussion in 'Gen 3 Prius Main Forum' started by AzusaPrius, Sep 19, 2021.
  1. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Will a Gen III with a Gen IV motor pass the visual inspection for California Smog? Or do they care? Or, would they even know?
  2. Montgomery
    2,254
    2,241
    Orange County, CA
    Folks!, Notice the Gen IV has the spin-on style oil filter! Wonder if Toyota likes it better?
  3. AzusaPrius
    AzusaPrius Senior Member
    2,180
    920
    I just recently got my car smogged.
    The tech didnt even care if I had a cat shield or aftermarket cat.
    Long as there is no codes.
    I even told him I swapped the engine and he just looked at it.
    I could probably get away with my intake still on and say it is a K&N next time, as he said those are allowed. Lol
    #143 AzusaPrius, Jul 2, 2023
    mikey_t likes this.
  4. Montgomery
    2,254
    2,241
    Orange County, CA
    I just did my tags last month and I needed to get a smog certification. The only visual thing under my hood is an Oil Catch Can system. The tech didn't seem to worry about it. The tech did look underneath the car. But yeah, he basically looked for codes, which my car is fine and issued the certificate. Since he looked underneath, I was wondering if he was looking to see if I had an aftermarket CAT.
    mikey_t likes this.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,462
    2,423
    Taylors, SC
    Which aftermarket cat did you use? An eBay, an Amazon $120 one or a higher grade one like Walker, AP or MagnaFlow?
  6. Montgomery
    2,254
    2,241
    Orange County, CA
    I don't have an aftermarket cat. I was just commenting on wondering what he was looking for underneath my car. I still have my original cat.
  7. Georgina Rudkus
    3,462
    2,423
    Taylors, SC
    Thanks. Just thought to see how others may be helped on how to get around those draconian CARB rules. If California really cares about the poor, there should be some sort of assistance or a waiver. My dad lived there in the 1980s. There was a waiver fro those who failed the smog, if a $50 repair did not meet the requirement to pass. How times have changed.
  8. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Early Gen 4’s had the paper filter option then they switch over to the spin on filters. Makes me wonder why? 2nd Gen has the same filters then changed the formula to paper on a Gen 3
  9. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    They were probably aware of some of the problems caused by their dealers' service techs over tightening the plastic cartridge housing for the oil filter.
  10. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    It’s getting to be a common thing to see something like this
    mikey_t and Burna J like this.
  11. ASRDogman
    ASRDogman Senior Member
    7,571
    3,904
    Don't worry, someone will buy them from you... :whistle:
    Montgomery likes this.
  12. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Where are/What happened to the springs?
  13. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Too complicated: clean this that, over here, there. Lube the gasket put the gasket in the right spot then lube the gasket again. Align cartridge with this orientation on installation or risk damaging the threads (oops that happened to me). Turn until it just bottoms out make sure the gasket didn’t move and the plastic housing mates to the adapter face, then torque to spec. (Did I miss something? I may have)!
  14. Georgina Rudkus
    3,462
    2,423
    Taylors, SC
    They've sprung and flew the coop. ;)
    RightOnTime and jzchen like this.
  15. ChapmanF
    18,147
    Springs Is Bustin' Out All Over
    jzchen likes this.
  16. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    At HybridPit for the EGR Service. Looking forward to the long overdue maintenance.
    mikey_t and Kromis like this.
  17. Montgomery
    2,254
    2,241
    Orange County, CA
    Sweet!....
    Xterra72 likes this.
  18. Mendel Leisk
    41,402
    First time? What miles? What do they charge? I suspect they do an ultra-complete job. (y)
    Rant:
    Just wish Toyota would isssue a comprehensive instruction to all dealership service departments, suggest a frequency to do it, and set/enforce a decent price, considering they screwed the pooch on it.
    And that instruction should involve cleaning, not replacement. If cleaning is impossible, parts replacement should be gratis. Supply dealership with chemicals, ultrasonic baths, whatever.
    Basically the opposite of their current stance.
    Merkey, Montgomery, Kromis and 2 others like this.
  19. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    It’s always a pleasure to work on cars from PC Let the magic begin…….
    mikey_t and Xterra72 like this.
  20. xliderider
    8,140
    3,276
    Honolulu, HI
    Ditto, how many miles on the odometer?
