Possible head gasket failure. Help!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Emm, Jul 5, 2023.
  1. Emm
    Emm Junior Member
    42
    Covina
    Unfortunately another head gasket post
    Last night our check engine light turned on. Gave code 0303 cylinder 3. Checked the coolant and it's a little under the low line. This is for sure head gasket, right? We live in San Diego and gasketmasters said it was okay to drive it up to Montclair (about 2 hours with traffic). Is it really okay to drive it like that for 2 hours? We also called SD hybrids in San Diego and they recommended to just change the whole engine for a refurbished 6,000 mile one for $3750. They said there's no point changing head gasket only so they won't even try to do it. They will only change the whole engine. We cleaned egr system 18k miles ago and it's currently at 188k 2012.
    Can't do it ourselves since we live in apts and we have to move out by end of this week
  2. Brian1954
    Brian1954 Senior Member
    2,229
    877
    South Central PA, USA
    How long have you owned the car?
    Were the spark plugs replaced at the recommended 120k miles?
    Do you have misfires during cold startups after the car sat overnight, or do you have misfires when you are driving after the car warms up?
    If this is the first time that you noticed the engine coolant being low, I would fill it up and keep a close watch to see if it goes down again. If you can confirm that it is losing coolant, it probably is a head gasket failure.
    #2 Brian1954, Jul 5, 2023
  3. Emm
    Emm Junior Member
    42
    Covina
    we got it brand new. I think we’ve been hearing the rumbling at start up but thought it was probably because we were parked to close on top of to the curb and it was hitting under the car? The check engine light turned on after we drove somewhere and came back to head home after 3 hours. We changed the spark plugs around 165k. This is the first time we have noticed only because the check engine turned on.
  4. Mendel Leisk
    41,512
    EGR cleaning at 170K miles is pretty late. Accordingly I'd suspect head gasket. The p0303 misfire code (misfire on cylinder 3) is a little odd; typically it's cylinder one or two.
    Head gasket replacement only is a viable option. DiY without machine shop overhaul of the head (just DIY verify flatness of head/block machined faces, and valve sealing) would be around $300~400, for Toyota gasket kit and new head bolts. Independent mechanic doing the head gasket only, maybe a grand more?
    Boroscope inspection of the combustion chambers (with cooling system pressurized, looking for coolant leaks) and/or leak-down test are the best tests.
    Did you clean the EGR system personally?
    If not, did you see the components, before and after?
    How did it look?
    Did the intake manifold also get cleaned?
    Do you get shakes at cold start-up? Or no?
  5. Emm
    Emm Junior Member
    42
    Covina
    Problem is we only have this week to get it fixed before driving it cross country (moving).
    We did the cleaning ourselves. The egr was pretty clogged. Couldn’t even see through it. We cleaned manifold too and the little front holes in the manifold. Changed PCV valve and coolant.
    I think it’s always had a little rattle (not really noticeable) but yesterday after heading home from the car being parked for 3 hours, husband thought he heard something after turning it on and the check engine light turned on.
  6. Tombukt2
    13,036
    2,336
    I go with the change the engine for a replacement from the JDM.o bought a transmission to go with mine so both pieces are low mileage . Now only chassis has the miles.
  7. Emm
    Emm Junior Member
    42
    Covina
    Can’t change it myself. We have till end of the week to move out :(
  8. Evelyn Shepherd
    Evelyn Shepherd Junior Member
    Arkansas
    2013 Prius v wagon
    There’s a product called Irontite pour it in your reservoir tank it works miracles.
    #8 Evelyn Shepherd, Jul 5, 2023
  9. JC91006
    JC91006 Senior Member
    16,769
    8,567
    If your water pump hasn't been changed, that might be the reason for the head gasket failure. I would highly suggest you don't rush this repair and have to repeat it.
    AAA top tier (not sure what that's called) will tow your car 200 miles for free, or the Gold membership will tow it 100 miles for free. You can drive it up north a bit from San Diego and get it towed to where you want it to go (within 100 miles if you have gold membership)
  10. Mendel Leisk
    41,512
    "Covina" is a Los Angeles suburb? Contact Hybrid Pit Stop (also in LA); they do quality Gen 3 Prius engine swaps, have rebuilt engines sitting at the ready.
    https://hybridpit.com/contact/
    @RightOnTime @GregC1979 are a couple of Priuschat members in their employ.
    Brian1954 and RightOnTime like this.
  11. Radiospank
    Radiospank Member
    169
    77
    If you could diy it would be awesome, I just changed my HG and cleaned up the head and valves to almost new condition, runs great now and no more rattle on cold starts. However given your circumstances I would say gasket masters is a good choice and it is definitely safe to run even on low coolant because I was low on coolant for awhile and didn’t even know it lol. That’s also how I knew my HG was way overdue for changing. I honestly don’t think you need a new engine, that’s silly imo but it’s actully not a bad price for a newer engine to kinda start fresh, but given how long these motors go for I don’t think it’s necessary.
  12. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    +1 Hopefully they can replace the head gasket, etc. within the short time frame. No way would I risk driving across country with a blown head gasket.
    iPhone ? Pro
  13. Mendel Leisk
    41,512
    Don’t do it! :eek:
    Radiospank and CR94 like this.
  14. Emm
    Emm Junior Member
    42
    Covina
    MikeDee likes this.
  15. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    We love working on Prii’s all day! Just make sure you get the water pump
    Checked out and to check to see if there are any bent rods while disassembled. If you have any questions give us a call at the Shop
  16. Tombukt2
    13,036
    2,336
    If You can't do any of this yourself then you're going to be paying retail I guess you're in California and unless you know people and East LA and have connections I guess out there you'll be paying the 6K 5K 4K whatever it is. As in this day and age there is no wiggle room and everything is pretty much pumped up to maximum retail at the moment because it can be.
    Radiospank likes this.
