Prime Owners: Tips, Notes and Observations
Discussion in 'Gen 5 Prius Main Forum' started by Exerted, Jun 27, 2023.
  1. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    I use PRI stabilizer (much better than Stabil) for any ICE that will sit more than a couple months. Highly recommended! Of course use the Pure Gas site to find ethanol-free gas near you.
    Exerted likes this.
  2. Mendel Leisk
    41,901
  3. Trollbait
    12,680
    Had crystals form in an old bottle. Just a few. Probably just added the liquid to tanks of lawnmower gas.
    Exerted and Mendel Leisk like this.
  4. Numtini
    Numtini Member
    91
    94
    Cape Schrod
    2023 Prius Prime
    XSE
    We just did a 3 hour 167 mile trip and it was exactly as you say, it used the EV mode heavily until 86% and then wavered between 85 and 86, concluding with a 4 mile downhill on a back road that charged us back up to 92. Trip MPG 52.7. We have a XSE/19" wheels.
    Over a few hundred miles of mostly small town roads, I'm averaging 4.6mi/kwh. I've managed to get it up to 6 on individual trips. Range is a very consistent 52 miles.
    tovli, raqball, Exerted and 1 other person like this.
  5. bisco
    52,390
    That’s fabulous!
  6. Exerted
    Exerted Member
    110
    100
    2023 Prius Prime
    Ran the tank 8 miles past empty, and filled up approx. 9.6gal which leaves a gallon in reserve.
    52mpg average along with the 8 miles gives me about 60 miles of emergency reserve.
    otatrant and thetoys like this.
  7. thetoys
    thetoys Member
    28
    Toronto, ON
    2024 Prius Prime
    XSE Premium
    Cool. Good to know in general how much range to expect after empty. 60 miles is a good amount range to find a Gas Station or Level 2 charger.
  8. flim
    flim Active Member
    260
    183
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    Decided to install my new car plate today and was surprised to see this under the plate holder. (y) IMG_4983.jpeg
    tovli likes this.
  9. bisco
    52,390
    that's cool, i'd want a clear plate :cool:
  10. Ngenovesi
    Ngenovesi Member
    51
    28
    Pittsburgh
    2023 Prius Prime
    Got my new 2023 Prius Prime Premium Cutting Edge and very pleased. Had to go to Rochester NY to get it. 270 mile trip. MSPR and no BS. Question is when I was driving back I couldn’t tell how much MPG I was getting combining EV with HV lick I could on my Gen 4. Am I missing something is there a way to see this. Looked in manual and didn’t see it. Thanks to all Prius Drivers.
    mountaineer likes this.
  11. Numtini
    Numtini Member
    91
    94
    Cape Schrod
    2023 Prius Prime
    XSE
    The only way I know of to get an accurate MPG is to reset the MPG counter after you switch to HV or run out of EV range. Otherwise it will count the EV miles towards your MPG giving you a vastly inflated figure.
  12. Ngenovesi
    Ngenovesi Member
    51
    28
    Pittsburgh
    2023 Prius Prime
  13. mountaineer
    mountaineer Active Member
    146
    115
    Hamilton, ON
    2019 Prius Prime
    That is my biggest gripe with the Gen 5. You can't track your gas/battery consumption properly.
  14. Will B
    Will B Active Member
    443
    408
    Denver
    2023 Prius Prime
    XSE Premium
    @mountaineer : I agree, after 20 years of precisely tracking efficiency on my Gen1 I feel kind of lost on the Gen5. For now I'm just tracking EV-only range/efficiency since that is possible, but way to messy to do anything realistic with gas that I can see. I just reset Odometer B on every charge and then note miles and battery percent if I get home with it low or when it gets down to 0 in-trip.
    will
