Hitch Install problem
Discussion in 'Gen 4 Prius Main Forum' started by dpframing, Jul 6, 2023.
  1. dpframing
    dpframing "Nobody tells me what to do, not even me."
    78
    Chester NY 10918
    2022 Prius Prime
    On my 3rd Prius- I was all excited since my 2005 and my 2013 recommended NO TOWING and my 2022 Prime can tow 1598 lbs. I found out Toyota does not make an OEM hitch for the car. So eTrailers has one with a wiring kit for the car. I call my dealership service dept. and I was told that the aftermarket hitch and the install will VOID my Platinum 7 year VSA coverage which cost me $2000. AND the service guy told me he wouldn't even install it if I paid the dealership to do the work. So essentially, I can't have a hitch installed because it will void the warranty. Anybody else run into this illegal move by Toyota?
  2. Mendel Leisk
    41,913
    Where'd you see that? In the 2022 Prius Prime Owner's Manual:
  3. Doug McC
    Doug McC Senior Member
    1,082
    421
    Midwest
    2022 Prius
    My 2022 Prius XLE Nightshade manual says the same thing as Mendel showed.
    So not much of an “illegal move” by Toyota that I can see. (n)
  4. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    Find an independent mechanic or even a body shop to do the job for you.
    Georgina Rudkus likes this.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,501
    Taylors, SC
    That's one reason why I would never buy an extended warranty. I'd invest my $2,000 and keep it all with seven years in proceeds. $2,000 will cover most all repairs and there would be no exclusions or escape clauses on covered repairs.
    That insurance policy called an extended warranty covers all their ad costs, their celebrity endorsements, if any, all their administrative fees, ther commissions and still makes them a tidy profit.
    And, most policy holders don't make a claim.
    AzWxGuy likes this.
  6. Plugin_RK
    Plugin_RK Member
    100
    31
    Pacific Coastal city
    2018 Prius PHV
    1598lbs converts to 725kg, which is Toyota's rated towing weight for many Prius hybrid models - possibly including the 2022 Prius hybrid:
    Towing the line with the new Toyota Prius - Toyota UK Magazine (dated 2016)
    Toyota Hybrid towing: your questions answered - Toyota UK Magazine (dated 2020)
    And the 2024 Prius Prime appears to have a similar rating:
    2024 Toyota Prius Prime: A Comprehensive Guide On Features, Specs, And Pricing
    However, I don't know if this includes the 2022 Prius Prime, which the OP originally asked about. His dealership may be nervous because that particular model i.e. 2022 Prius Prime, is not recommended for towing by Toyota.
    So, I imagine insurance companies should be able to cover any Prius and Prius Prime models, which do have a towing rating of 725 kg (or 1,598 lbs).
    I do wonder though, what the situation is for a Prius (or Prius Prime) using a Trailer Hitch (Stainless Steel) by EcoHitch, which is rated at 2,000lbs (907kg)? For example, the manufacturer of the towbar clearly has a rating of 2,000lbs for a 2018 Prius Prime, which seems to be more than Toyota's rating for the vehicle e.g. possibly as mentioned above for many models. Would insurance companies cover vehicles fitted with these towbars? Perhaps insurance cover would only extend to towing up to 1,598lbs (725kg)(if Toyota has recommended a towing weight for model concerned) but not when towing loads above this e.g. 2,000lbs?
    Torklift Central | Toyota Prius trailer hitch by EcoHitch®
    2018 Toyota Prius Prime Trailer Hitch | etrailer.com
    #6 Plugin_RK, Apr 5, 2024
  7. Plugin_RK
    Plugin_RK Member
    100
    31
    2018 Prius PHV
    A few day ago I asked a local manufacturer/installer of towbars if they would install an eTrailer hitch to our 2018 Prius PHV, which was imported from Japan. After looking at the hitch via 2018 Toyota Prius Prime Trailer Hitch | etrailer.com he said he'd be happy to install it as long as the manufacturer was reputable and provide a sticker with the design rating. When asked about legailty/insurance/etc he replied it is dependent on the jurisdiction. In his area (and presumably mine) the law would allow it as long as braking distances were within certain limits. He also said that insurance companies would provide cover if the vehicle passes the regular vehicle inspection e.g. annual certification check. I'd suggest you contact a local towbar manufacturer/installer regarding legal and insurance requirements in your locality.
    #7 Plugin_RK, Apr 27, 2024
  8. John6012
    John6012 Member
    134
    2018 Prius Prime
    I installed a receiver hitch from etrailer.com on. my 2028 Prius Prime Advance. Never consulted anyone to include insurance company. (USAA) and I expect no problems as long as I remain within the tow capacities of the receiver.
  9. Doug McC
    1,082
    421
    Midwest
    2022 Prius
    Glad to know that 4 years into the future we will be able to still buy one.
    PriusPaddler likes this.
  10. Charlie M
    Charlie M Junior Member
    Georgia
    I read that the Prius sold in Europe is rated to tow 750 kilogram. The vehicle is the same as sold in USA.
  11. Plugin_RK
    Plugin_RK Member
    100
    31
    2018 Prius PHV
    The weight rating for towing for many smaller Toyota hybrid vehicles in UK is 750 kg although the Prius is rated at 725 kg - which I believe is the same as in Europe. For example, read this 2020 article in mag.toyota.co.uk:
    There are reasons why different countries have different ratings. Some more detailed explanations can be found at:
    Why Tow Ratings are Different in the EU vs. the US | PriusChat
    https://www.motortrend.com/how-to/towing/1502-sae-j2807-tow-tests-the-standard/
    Great Explanation for USA vs EU Tow Ratings | Toyota RAV4 Forums
    I think it depends on lots of things, including: open-road speeds, road design, road surfaces, average/usual vehicle sizes and weights, common tow activities, etc. There is also the risk of litigious complications and insurance aspects. Then there is the legal framework especially whether car manufacturer recommendations are an integral part of the country's laws or whether they are only included in insurance policies' small print. Both the technical factors and the legal/commercial factors can be very different between countries.
    #11 Plugin_RK, Oct 7, 2024
