2020 prime 12v outlet not working fuses ok
Discussion in 'Prime Technical Discussion' started by mihlupca12, Jul 2, 2023.
  1. mihlupca12
    mihlupca12 Junior Member
    Quebec, Quebec
    HY, 12v outlet beetween front seats is not working, checked all fuses near the brake level and in the compartment engine. Is there another fuse for that outlet? if not what is the procedure to take out the module between the front seat.
    Also the bip bip noise is annoing is there a way to cancel he noise when the seabealts are not atached ?
    thank you
    Mihail
  2. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    Did you verify the fuse visually or with a multimeter? Sometimes hairline cracks in a fuse are not visible.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    The beep beep should eventually time out. At least it does in my 2016 Hybrid.
