Please help…..I Need Wiring Diagrams for 2007/2008 Hatchback
Discussion in 'Gen 2 Prius Main Forum' started by Michael Crestohl, Jul 13, 2023.
  1. Michael Crestohl
    Michael Crestohl Junior Member
    61
    Marblehead Massachusetts
    Man, am I having fun……
    I have a 2007 with all the bells and whistles especially the back up camera BUT the car came with a hatchback lid that has been replaced and does not have the camera or the little black button that I believe is part of the keyless system. I found a hatchback that has these two items and installed it on the car last night. However, the connectors from the car to the harchnack are not the same as those on the hatchback going to the car.
    Soooooooo……
    I would really appreciate having a wiring diagram for the hatchback as well as the corresponding connections on the car so I can connect the right wires together. I can’t just take the wirimg harness off the old hatchback because it doesn't have the wirimg for the camera or the black button.
    I believe the hatchback is from a 2008.
    Also can I buy the two hatchback connectors from Toyota or do they only sell the complete hatchback-side wiring harness?
    Thanks in advance,,,,.
    Michael
    Tombukt2 likes this.
  2. Tombukt2
    13,386
    2,408
    I think the SKS might ad wiring But the plugs are all different? I'll have to go out and look I have an '09 and an o five here The short nose and the later model my '05 is stripped and I can see the wiring but I think it has the buttons already so it was SKS although it wasn't working when I was running the car I would find that strange that even the two cars in the same year 2 05s one SKS with backup and one without SKS. Would have completely different wiring but I guess it's possible
  3. Tombukt2
    13,386
    2,408
    You are welcome to the SKS connectors or rear hatch connectors of my '05 SKS parts car It's loaded had navigation I think and backup camera I have to go look I'm not sure but I think so It had a fog lights and everything It's sitting right here.
    SFO likes this.
  4. Tombukt2
    13,386
    2,408
    In the rear of my SKS car looking up at the hatch with the cover off to the right of the sticker for the wiring harness there is a white plug taped up never been used probably the original plug that goes for non SKS so I would think the wiring for SKS would be taped up and not used in the base model I have pictures but I don't know how to post them here I don't think but you're welcome to the harness
  5. Michael Crestohl
    61
    Thank you for your kind offer. Let me send you photos of the connectors on the car side. Where are you located?
  6. Tombukt2
    13,386
    2,408
    I'm in Central North Carolina right next to the city of medicine which is Durham where Duke University is One of those ivy league colleges parents try to aspire to afford for their children.
  7. Tombukt2
    13,386
    2,408
    Like I say if you look to the right of the sticker for the wiring harness for the rear hatch I have a plug that's taped there I'm guessing that plug is being used in your car and the SKS plugs if we'll call them that are taped to the harness and not used would be my guess.
  8. Tombukt2
    13,386
    2,408
    [email protected] send me the picture and I'll send you mine and you can see what I'm talking about I would like to see you non SKS button car wiring differences for sure
  9. Michael Crestohl
    61
    Here are the connectors that are coming from the car side…..
  10. Tombukt2
    13,386
    2,408
    So these or actually on hatch not under headliner at center upper roof?. The bottom pic looks like what's taped up on mine shoot me an email to the address above and I'll send you the pictures of mine with all the numbers attached and you can figure out whether you can use it I'm sure it will work I will unplug it at the headliner pull it through and send the whole mess or I can whack off the plugs with wire and send that to you doesn't matter to me no problem I can never get pictures to post here
  11. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    Wiring diagrams here.
    Service Manuals - Google Drive
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    You might consider pulling the camera out and figuring out what part number it is and what car it's from. If the harnesses are different, then I don't know if the camera is compatible.
  13. Tombukt2
    13,386
    2,408
    So again to be clear when you remove the hatch off your 2007 base car you undid the bolts at the top of the hatch under the headliner and you unplugged the rear hatch right there under the headliner undid the little rubber boots and pulled the plugs through picked up the old hatch dropped it on the ground next to the car You put the newer hatch on reversing that process and the plugs that are above the headliner do not match up to the car? I find that highly improbable. Or are you saying further down the line on the back of the hatch where the other plugs are that go to the camera the backup lights any door buttons etc they don't plug up down there? I would think no matter what you have the plugs up under the headliner would be correct no matter what options you have I have both of those cars here and '09 and an '05 unfortunately the '05 and '09 here are both SKS cars but they do have the two plugs you're showing me in the pictures down below taped to the black corrugated or taped wiring harness way down the line level with the button you push to open the hatch I don't know how that plug would get all the way back up to the headliner usually the plugs under the headliner will fit all the cars I didn't think that ever got changed until they went to the generation 3 or another model which that's what that was.
  14. Michael Crestohl
    61
    Tom:
    Yes, that is exactly the situation. I am talking about the two plugs that are at the very top of the hatchback. I was very surprised that the plugs are different. The car is a base model and has SKS, navigation and the rear camera.. The hatchback that came with the car is not the original. It had been replaced and came from a vehicle that did not have SKS or the backup camera. I believe it is from a 2008 base model. It does not have the special spoiler that comes with the Touring model. Yet the two plugs in this replacement hatchback were the same and everything worked. However the hole for the camera was not there and neither were the wires. It is a different harness.
    The plugs (photos posted here previously) from the car pass under the headliner but are accessed in the hatchback at the top. I do not have to remove the headliner to get to them.
    I will email you direct the photos of the plugs that don’t fit the car’s plugs a bit later.
    Thanks again for all the help.
    Sincerely,
    Michael
  15. Tombukt2
    13,386
    2,408
    Yes you can pull the boots up and pull the plug to the top of the roof if you will but yeah I can't imagine the plugs being different they usually the same plugs and have more wires they usually the same plugs and have all the wires in place and then those wires are livened up when fuses are inserted in the fuse box or whatever goes on I can't wait to see this this is an America right? Very interesting I've got a bunch of hatches and quite a few cars here I think there's a non SKS here but personally I've not seen a rear hatch without the little silly spoiler above the glass or if I have I don't remember it so that is interesting that is a base base I didn't even know that existed quite interesting so the spoiler wasn't ripped off that hatch it just doesn't come on it. Well I'll have to go Google that now just to see what that looks like
  16. lexidium
    lexidium Active Member
    301
    143
    manchester
    The wiring diagrams are in the file library on here along with lots of other info.
  17. Michael Crestohl
    61
    Looks like I figured it out……. There seems to be another wiring harness that goes between the two sets of plugs. Thanks all for your help and assistance,
    Best,
    Michael
  18. Tombukt2
    13,386
    2,408
    There you go there's a sub harness like for some of the radios Very cool
