Gen 3 to gen 4 engine and transmission swap
Discussion in 'Gen 3 Prius Main Forum' started by SolarClint, Jul 14, 2023.
  1. SolarClint
    SolarClint New Member
    San diego
    Has anyone done a full swap of a gen4 engine and transmission into a gen 3? Is it possible without excessive modification?
  2. Tombukt2
    12,924
    2,322
    There's a bunch of posts here about the Gen 3 Gen 4 engine swap there's a cooling issue a hose issue a routing issue of another hose the transmission should be the same drive axles all of that so in other words your drive axles from the Gen 3 should plug right up into the Gen 4 transmission If not it would just be a simple as changing the inner CV joint so that the pattern matches but I'd be shocked if they're different still the two Z stuff fits . But I'm not fully lying that the stuff is fixed with the Gen 4 sleeves liners and whatever they've done there's been a few that have come back with the same problem I think in the Gen 4 so why do all that modification if there's any We just get a Gen 3 engine I bought the transmission too so I have both pieces being low mileage seem to work out pretty good so far.
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    Yes, there is an entire thread in PriusChat about this. However, there are some local Hybrid shops in your area that may do it. The one up here in the OC is Hybridpit located in Buena Park. If anything, you could give them a call and they could steer you in the right direction.
    Kromis likes this.
  4. Tombukt2
    12,924
    2,322
    With both pieces on deck and out of the car you should be able to take a Gen 4 engine and or Gen 3 or 4 transmission made all that up together and create whatever it is you need redo the line that needs being taken care of or deleting whatever much easier with it all out of the car plop it in hook it up It's a reasonably straightforward job
