Bought 2008 Prius - Overheating (Red Triangle)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gburke1, Jul 15, 2023.
  1. gburke1
    gburke1 New Member
    MI
    I bought a used Prius cheap off Facebook Marketplace to use for gig work. It drives great other than losing coolant then overheating / red triangle. Has 340K miles.
    What I know so far (also pic of scan from AutoZone attached).
    Has the following codes: P1121, P1150, P1151, P0300, P0302, P0304, P0420.
    Coolant Flow Control Valve seems dead as the P1121 suggests. Tried jumping it via the relay and it won’t come on (the car was completely off when I tried to jump it - not sure if that matters).
    12v battery seems fine based on the check signal screen. Reads 12.4-12.5 and 12.2 with slight load. Goes up to 14.4 when car is started up.
    There is the smell of coolant around the car, I can’t tell for sure if the smell is in the interior
    I drove it about 130 miles the other day after refilling the coolant via the radiator cap and letting some of the air burp out. After that got the red triangle, let it cool down and added more fluid.
    Keeping it parked for now until I replace the Coolant Flow Control Valve and radiator cap, plus bleed out all the air via the radiator cap.
    Toyota told the prior owner it needed new radiator, coolant heat storage tank, coolant flow control valve.
    Based on the scan from AutoZone looks like it also needs some new spark plugs.
    Anyone see something here that suggests I will need to do more to stop the overheating than just replacing the coolant flow control valve / bleeding the system?
  2. Tombukt2
    12,045
    2,132
    Are you spilling coolant as you're putting it into the radiator? You really need to find where that smell is coming from a seeping hose something like that The bottom of the water pump dripping? You know this water pump has a belt on it It's activated kind of like an air conditioning compressor your air conditioning compressor is electric no belt but your water pump has a real skinny belt going around it Do you see it on the car on the front of the engine which is on the passenger side? No belt no coolant circulation bad. A 2008 at this age could have permeated hoses so if it gets warmed up before it overheats do you see any coolant weeping very slowly right through hoses? Are you sure you're overheating does the red triangle go away right after you add coolant and turn the car back on? No I don't know all those codes bite memory I have to look them up manually and receive them on the scanner and get the basic text from below each code these are p codes so any scanner should get them pretty much.
    donbright likes this.
  3. gburke1
    gburke1 New Member
    MI
    Yeah the red triangle goes away once you add coolant. It comes in intermittently and goes away when you slow down (when the engine cools down I guess.
    The details of the codes are shown in the photo - 1150 and 1151 are coolant heat storage tank and 1121 is control flow valve. The 0300-0304 codes are misfires and 0420 I think is related to the catalytic converter
  4. gburke1
    gburke1 New Member
    MI
    I do think the hose connected to radiator may be loose (just eyeballing) - the clamp is rusted and it does not sit flush with the radiator. Can see maybe a half inch or inch (can’t remember off hand) of the right side of metal pipe you connect the hose to. Will have to take pics and find out if there are any leaks (I have spilled fluid on accident a few times so can’t tell if there is any leak at the moment)
    To clarify my last post - the triangle didn’t show up the other day when I drove it until 130 miles in … then adding coolant (via radiator cap) made the triangles stop, and I was able to drive it back home.
  5. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    is the coolant pump ok?
  6. gburke1
    gburke1 New Member
    MI
    Originally I posted that the Coolant Flow Control Valve is dead. I thought that was the noise when you turn on the vehicle … turns out the noise is the pump for the Coolant Heat Storage Tank. The coolant heat storage pump still comes on when I turn on the vehicle, or if I press the brake pedal several times with the car off. However, I can’t seem to jump the pump using the relay. Tried replacing fuse 44 for the CHS W/P and still cannot jump the pump using my multimeter set to 10 amps.
    This morning I burped the Coolant Heat Storage tank then worked on burping air out of the heater core. I followed the process shown by the Youtube channel Eyeonaiman that goes pretty in depth about bleeding the system - except I had to keep using the brake pedal to turn on (for about 5 sec each time) the pump since I can’t seem to jump it.
    There was definitely a lot of air in the system, think it took about 2 quarts. This did not solve the problem - drove around 80 miles today and red triangle was back. Added more coolant - triangle gone - parked it.
    Tomorrow I’ll try to tighten that loose looking hose and bleed again. I do wonder if that hose could be leaking and/or letting air into the system. May have my answer tomorrow morning as I cleaned up the garage floor so that it was dry before parking.
    The radiator hoses are hot when the car comes to temp - so it does seem like the coolant is flowing. From what I am reading - despite my P1121 - the Coolant Flow Control Valve is unlikely to solve my problem … is that correct?
    I suppose Toyota’s diagnosis for previous owner could be correct (needs new radiator and coolant heat storage tank)
  7. gburke1
    gburke1 New Member
    MI
    Here are pics of the hoses I suspect may be loose. Is it normal for that much of the metal to be exposed? Seems like it should be pushed all the way on so that it sits flush?
  8. dolj
    dolj Senior Member
    8,187
    4,169
    Wellington, New Zealand
    That should not be a problem, but you can always push it on all the way if you wish.
    #8 dolj, Jul 18, 2023
    gburke1 likes this.
  9. mr_guy_mann
    mr_guy_mann Senior Member
    3,948
    1,901
    NJ-USA
    Coolant loss + overheat + misfire (codes) = likely head gasket problems.
    Ignore the coolant valve and CHS tank for now. I would have a shop pressure test the cooling system while the spark plugs are removed.
    Unless the radiator is actively dripping coolant under pressure, I would ignore it for the moment as well. Have the technician inspect the engine cylinders for any coolant with a videoscope.
    gburke1 likes this.
  10. gburke1
    gburke1 New Member
    MI
    IMG_0228.jpeg IMG_0229.jpeg There does seem to be a slight leak, around the driver side, right where the potentially loose hose is I showed earlier. Maybe it could be leaking more while under pressure or could be coming from somewhere else?
    I checked the dipstick too, not knowing what to look for and based on very quick Google search looks ok? Could definitely be wrong about that.
    Taking it to a mechanic is unfortunately not possible for now. This is basically a gamble that it will last long enough to at least pay for itself and then some. I just don’t have the funds to do that right now, even if it ultimately means it blows up. If I get another month or two out of it, maybe.
    #10 gburke1, Jul 19, 2023
  11. dolj
    dolj Senior Member
    8,187
    4,169
    You need to wipe the dipstick clean, put it back in, wait a few seconds then take it out again. As long as the oil level is between those two dimples you are golden. Ideally, the level should be checked when the engine is cold as warm oil will show a higher level.
    If the level is more than two-thirds down you can add a qt of 5W-30 oil to bring the level up. It takes 1.6 qts to raise the level from the bottom dimple (the Low mark) to the top dimple (the Full mark). Never go more than 1/8" over the top mark–below but 1/8" - 1/4" is better.
    #11 dolj, Jul 20, 2023
  12. gburke1
    gburke1 New Member
    MI
    IMG_0234.jpeg IMG_0233.jpeg Did what you suggested. Here are both sides of the dipstick … doesn’t look milky to me but again not sure exactly what it would look like if it was milky … I saw some that looked more like jelly on Google but not sure if that was an extreme example of coolant mixing with oil.
    Prior owner claimed to change oil 2K miles ago (2700 now)
    #12 gburke1, Jul 20, 2023
  13. dolj
    dolj Senior Member
    8,187
    4,169
    No, that is not milky and looks to be a little under 0.5 qt down which is fine for now.
    gburke1 likes this.
  14. gburke1
    gburke1 New Member
    MI
    IMG_0271.jpeg IMG_0270.jpeg 71478700915__59BCF61B-7086-48BD-BF19-262B878E0B8B.jpeg Little update on my situation. Since buying, have now put ~5K miles on it.
    Got an oil change the other day, they didn’t see coolant in the old oil.
    Today I found several spots in the engine bay with coolant residue (see photos), so maybe there is a leak? (or would a head gasket issue cause this?)
    I also kind of suspect heater core could be the issue but it’s hard to tell if coolant smell from vents is just due to coolant being in the engine bay or if it’s actually heater core. Both AC/Heater work. Also not sure how likely it would be in light of the coolant residue I found today.
  15. Tombukt2
    12,045
    2,132
    To be honest you should be able to take a generation too out for a decent run country state road whatever get it warmed up pull back in your driveway or pull into a Walmart parking lot whatever makes you happy whip up the hood and you should be able to smell coolant not necessarily burning but touching warm things and has that wonderful smell if it's coming up where you're showing pictures of that pink against the engine there is what it looks like that will just waft up hit the hood and get sucked right into the air intake for the fan drug across the internal cabin filter and put right out the vents so you're going to smell it in the cabin especially running the fan air conditioning and or heat. I'm pretty sure the smell you're smelling is coming from those pink spots that you're showing whether that's head gasket blowed out that's not very normal usually head gaskets and modern engines don't blow and blow cooling out of that seal all over the outside of the externals that usually goes the other way gets pumped through the piston and engine what have you Not saying it's not possible to happen it's just I don't see that much maybe it's not for me to see. It looks like whatever is going on there might be dripping out of a hose something getting it's being squirt out of a fine pinhole and a hose something but can't be happening very often because you don't talk about losing coolant so there's always that It's got to go somewhere if it's making big pink spots there should be missing coolant.
  16. gburke1
    gburke1 New Member
    MI
    It is definitely losing lots of coolant. Going through about 1 jug every 3-4 days
  17. Tombukt2
    12,045
    2,132
    Looks like there's a leak somewhere around that big red pinkish stain something's got to be squirting It doesn't have to be a big fire hose 3/4 in directly squirting It can be when the engine moves a little bit the hose opens up let's cooling out so on and so forth I mean it's not showing up in the oil so it's got to be going the other way if it's actually happening internally inside the engine per se like the head gasket it's just not common on this engine but that doesn't mean it can't happen any ice engine can blow a head gasket. But it just looks like something external is going on or more external a hose expanding and squirting fluid comes to mind more than anything or a rubber to metal connection and the metal is failing again with straight or 50% mixes of the red coolant should not be allowing metal to be failing with the coolant is very old and those properties are gone.
  18. gburke1
    gburke1 New Member
    MI
    I am going to replace the 3 way pump and see what happens … the leak is near-ish to the pump and I already bought the pump a while back so it’s too late to return it, and I do have P1121. There are a lot of corroded pieces of metal around the 3 way pump.
    The leak / pink crust build up I posted photos of is on the inverter side of the engine bay - but doesn’t seem to make sense that part of the inverter loop would be related … since it’s losing coolant in the engine coolant loop.
    If this doesn’t work then I’ll try replacing some hoses (trying to find info on how many hoses / where to buy / cost etc.) and/or the coolant heat storage pump, as I also have P1150.
    Could blown head gasket cause the residue/crust on inverter side ?
    Tombukt2 likes this.
  19. gburke1
    gburke1 New Member
    MI
    Accidentally double posted
  20. Tombukt2
    12,045
    2,132
    Yes the three-way valve usually they don't leak they start making the noise or something I've only replaced one and I don't think it needed being replaced but I did it anyway to see if that would stop something I can't remember what and didn't make any difference really I don't think the pink crust is from a head gasket leak more like a hose pissing just a little stream like when the engines rocking or when everything is warmed up to Max something that's not very big of a leak it doesn't look like it looks like a very fine piss.
