Toyota Connected Services
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Hammersmith, May 7, 2023.
  1. daisy555
    daisy555 Senior Member
    1,715
    711
    CT
  2. 2023p
    2023p Member
    156
    94
    Here
    2023 Prius
    I have an LE and it does have TJA.
    Maybe I'm misunderstanding something.
    The car will essentially drive its self if I allow it and adhear to some simple attention.
    Tideland Prius likes this.
  3. Tideland Prius
    16,560
    From Toyota
    I believe it also requires a subscription (after the 3-year free trial). It basically does the acceleration, braking and steering. Compare to DRCC which only does the acceleration and braking and LTA which does the steering but within the lane (lane centering) but requires hands on the wheels.
    TJA is a hands-free system.
    2023p likes this.
  4. 2023p
    2023p Member
    156
    94
    Here
    2023 Prius
    Ohh, sheesh. So TJA doesn't require hands on the wheel every 30 or so seconds? Wild
    I definitely didn't realize that.
  5. AndersOne
    AndersOne Active Member
    335
    195
    Europe
    2023 Prius Prime
    Exactly - but then it needs your eyes on the road (thats what the sensor next to the steering wheel is for). Im honestly not sure if thats actually more annoying compared to the "hands on wheel" check. When im bored in traffic (especially with a passenger) I might start to look around.
    We will see in a few months what drivers say about it after having some experience with it.
    #45 AndersOne, Jul 18, 2023
    2023p likes this.
  6. Hammersmith
    Hammersmith Senior Member
    2,315
    2,349
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The others have already described what TJA is. What you're talking about is Lane Tracing Assist(LTA). There's also Lane Departure Warning w/ Steering Assist.
    LDW: Applies to most speeds and situations. Gives a moderate jerk of the steering wheel to bring the car back into the lane if it starts to drift across a line. Temporarily turned off if turn signal is activated first.
    LTA: Operates when cruise control is on. Gives small steering inputs to keep car in center of lane. Requires driver to move steering wheel every 15 seconds or so or it gives a warning and eventually shuts off.
    TJA: Only on the Prime. Operates at speeds under 25mph. Totally hands off but requires eyes to be on the road almost constantly. Maintains distance from the car ahead and keeps the car in the center of lane. Automatically deactivates(after giving a warning) if the car accelerates past 25mph(approx.) or the car in front accelerates quickly enough and moves beyond a certain range.
    2023p and Preebee like this.
  7. 2023p
    2023p Member
    156
    94
    Here
    2023 Prius
    Interesting. Thanks for the clarity.
    So as far as I have experienced it, the LE acts exactly like TJA when both adaptive cruise control and lane assist are enabled at the same time. And just requires hand in wheel every 30 seconds or so. Sans the camera eye pay attentioner tech.
    That's been my experience on the LE side.
    Those that have both cars care to comment of differences beyond semantics and the camera eye thingy, in real world experience?
  8. 2023p
    2023p Member
    156
    94
    Here
    2023 Prius
    Whoops, adding that regardless of speed almost identical in description based on my experience of the two like options, LE requiring a coupling of the two in order to achieve.
  9. Hammersmith
    2,315
    2,349
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Does adaptive cruise control work all the way down to a stop or does it kick off at some point? I don't live in an area with traffic jams to test.
    2023p likes this.
  10. 2023p
    2023p Member
    156
    94
    Here
    2023 Prius
    In my experience, the car will stay in lane, curve with any freeway as it twists and turns, regardless of traffic speed. Slow and stop as traffic does.
    Just pick a lane that is not the exit or entrance on freeway, hands on wheel etc
  11. 2023p
    2023p Member
    156
    94
    Here
    2023 Prius
    Great question, it goes to smooth stop and (rare occurncr seemingly, based on traffic) and then a tap or slight push in gas to get it to continue once traffic moves.
    Since TJA sounds like it doesn't require the user to tap gas once traffic moves past 0 mph.
    This tech is wild.
    Definitely a giant difference
  12. AndersOne
    335
    195
    Europe
    2023 Prius Prime
    I think the normal AAC (actually FRAAC)just needs a push when the car stops longer than a few seconds.
    2023p likes this.
  13. Kostomarov
    Kostomarov New Member
    Киев
    2012 Aqua
    How to set it up?
  14. Ronnie5
    Ronnie5 Member
    47
    51
    2023 Prius
    Press the upper left hand button on the steering wheel to show the multi-information display (if it's not already showing to the left of the speedometer). Scroll down and select the vehicle information icon, scroll left or right until the screen showing the pressure of each tire is displayed.
    2023p likes this.
  15. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    Does anybody know how to get the Drive Connect subscribe pitch from popping up every time you start the car?
    tovli and HacksawMark like this.
  16. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    Yes, it's annoying. Hopefully, it goes away when I don't subscribe.
  17. Preebee
    867
    771
    Midwest
    2023 Prius
    I never got a trial subscription. This is the Nav subscription. It's been hounding me since day 1.
  18. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I don't have nav in mine as I use Apple carplay. Mine gives me a pop-up for the wi fi.
  19. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    351
    273
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Not "every time" achieved by leaving Apple Maps running when I shut off the car, but occasionally I have to push the icon to connect CarPlay.
    IIRC you are a "droid" but should work the same, no?
  20. Techelet
    Techelet New Member
    Kansas City
    2023 Prius
    I love this feature! And one of my tires is 38 while the rest are 41...
