What to replace after 13 years and 167k miles?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by UpperPriusSide, Jul 21, 2023.
  1. UpperPriusSide
    UpperPriusSide Junior Member
    NYC
    My 2010 has hit around 167k miles but has held up better than any car or motorcycle I've ever owned. I realize that with more distractions now, I've taken its reliability for granted and want to be more proactive. I'll likely keep it for another 2 or 3 years. My question is - what should I consider replacing, aside from the shock absorbers, given the mileage and age? I've already replaced the accumulator/actuator, 12V battery, and front pads.
    Thank you for your perspective.
    Also, I would highly recommend never patronizing North Hollywood Toyota.
  2. OptimusPriustus
    OptimusPriustus Active Member
    308
    131
    Finland
    Have you thought about budget you’re willing to invest?
  3. bisco
    49,359
    clean the egr circuit
  4. Mendel Leisk
    38,635
    Water pump (aka engine coolant pump) along with adjacent thermostat, is worth replacing. They seem to get into “failure zone” around 150k.
    I’d second aforementioned EGR cleaning; see first two links in my signature*; hopefully not too late.
    * on a phone turn it landscape to see signature.
