crashed prius
Discussion in 'Gen 3 Prius Technical Discussion' started by Mehmet alb, Jul 23, 2023.
  1. Mehmet alb
    Mehmet alb Junior Member
    77
    Turkey
    2011 Toyota prius I'm thinking of buying this vehicle. Will it cost me a lot? I have a limited budget, but would you recommend? How much will it cost me to repair?
  2. rjparker
    10,156
    6,313
    Yes it will be costly to repair the obvious and plan on another $10k for engine, battery and brake by wire mechanicals.
    Montgomery, TGrracie and Mehmet alb like this.
  3. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
    I would NOT recommend buying this car /
    That looks like it could be really a money pit /
  4. Mendel Leisk
    41,463
    How much are they asking? What’s the miles? What’s your skill set; are you a mechanic?
    Mehmet alb likes this.
  5. Mehmet alb
    77
    Turkey
    They want 7000 dollars, the vehicle is in Turkey, it's a bit difficult myself, but I have to get it repaired.
    they could not start the vehicle, so the mile cannot be read. I can replace the batteries myself. I have experience with batteries.
  6. rjparker
    10,156
    6,313
    If its not yours now, turn around and run.
    Montgomery and Mehmet alb like this.
  7. Tombukt2
    12,989
    2,328
    Even with the conditions in Turkey I don't know man that's not going to be a thing you want to be involved in I can assure you that maybe a piaggio scooter until you can figure it out at least you're moving.
  8. Mehmet alb
    77
    Turkey
    Wouldn't it be enough if I bought a front bumper and a rear bumper?
  9. Tombukt2
    12,989
    2,328
    No I truly don't believe so mehmet. You will need a lot more than that to get that car even a quarter of the way straight but hey if it's something you want to t tackle.
  10. Mendel Leisk
    41,463
    There should be a placard inside drivers door opening, saying the month and year the car was built. Maybe post that.
    a lot of potential problems with this generation of Prius though.
  11. rjparker
    10,156
    6,313
    What $7,000 gen3 year would be ok in that condition?
  12. Mehmet alb
    77
    Turkey
    İ
    İt is normal in turkey
  13. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    This vehicle needs a lot more than new bumpers or batts; a lot more. Unless you're in the repair business with the tools, knowledge and space; pass.
  14. Mehmet alb
    77
    Turkey
    front bumper, rear bumper and rear and front bodywork, front and rear headlights, however, are different. Even if you write one and you are understandable, what you say is not understood
  15. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Normally it is not necessary to "start the vehicle" (which I take to mean put in READY mode) to read the odometer. It must have a 12-volt battery connected, though.
  16. Mehmet alb
    77
    Turkey
  17. Mehmet alb
    77
    Turkey
    The vehicle didn't start due to the accident, I'm assuming at most 70,000 miles, the vehicle looks great cosmetically. I thought the mile was low because the cosmetics were good. I have experience in battery and battery, I can handle it. My question is, will this tool work for me? excluding battery part
  18. rjparker
    10,156
    6,313
    I think you will regret buying it. It is a very complex vehicle and the battery is the least of the concerns.
  19. Mehmet alb
    77
    Turkey
    Başka hangi sorunlar ortaya çıkabilir? Açıklayabilir misin
    What other problems might occur? Can you explain
  20. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Buy it! Then use members’ referrr codes here to get a discount, we have members that will give you 24/7 support over the phone also!!!
