Source of 12 Volt power under the hood
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Nicad, Jul 20, 2023.
  1. Nicad
    Nicad New Member
    ontario, canada
    2023 Prius
    Limited AWD-e
    will be upgrading the horn and would like to run a relay as the horn I choose will draw more power than the stock system. Is there a clean way to tap into a 12 volt source under the hood? Tia.
    52,371
    Idk about gen 5, but gen 3 you could unbolt the 12v at the jump point. Since they put the battery back in the hatch, it might be similar
    Nicad likes this.
  3. Nicad
    Nicad New Member
    ontario, canada
    2023 Prius
    Limited AWD-e
    Good point, I think I noticed that when I removed the fuse box cover.
  4. Paul Gregory
    Paul Gregory Senior Member
    2,227
    592
    Alberta
    2024 Prius Prime
    XSE
    Under the fuse cover, near the booster plate, there is a 10 mm nut on a lug that can take a ring terminal. It's a direct line from the battery.
    RandyPete and purplePriii like this.
  5. Mendel Leisk
    41,882
