At what mileage do you lose your first pip?
Discussion in 'Gen 2 Prius Fuel Economy' started by stanleyjohn, Dec 12, 2006.
  1. stanleyjohn
    stanleyjohn New Member
    269
    Higganum,Ct
    During the summer i lose my first pip at about 105 miles which seems abit high!now its about 80.I wonder if there is a change to the fuel bladder due to the outside temps?
  2. Schmika
    Schmika New Member
    1,617
    Xenia, OH
    Yes, do a search on fuel gauge or bladder for more info. The bladder affects how much gas is in the tank and thus, when the first pip goes. Cold definitely plays a part. I have lost the first pip at 25 miles before.
  3. Tripod137
    Tripod137 New Member
    145
    Long Island
    Last weekend...in the 40-50F area...I lost my first one around 110 miles. (All highway driving, basically)
  4. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    During the warm part of the year I can get 150 miles but it does down to 40-50 range after that.
  5. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Like huskers, i see a very wide range on the DTD (distance to disappearance) of the first pip, mostly determined by temperature. Lower temperatures not only shrink the bladder, giving you less capacity for that "overfill" that makes the first pip disappear so long, it also creates longer warm up times and such that your mileage lowers - the same volume of gas disappears over a shorter distance traveled. It's like a 1-2 punch, you just can't recover :p
  6. Tideland Prius
    16,554
    <div class='quotetop'>QUOTE(stanlwyjohn @ Dec 12 2006, 04:41 PM) [snapback]361250[/snapback]</div>
    Yeah it's the weather. Here are my experiences
    new: 50-70kms
    last summer: peaked at nearly 160kms
    now: under 100kms
  7. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    Yes, when it gets cold outside, the bladder contracts, making it hold less gasoline. You really have to force that last couple of gallons in. When I know for certain that the tank is completely full, I generally get 130 to 160 miles on the trip before the first pip goes out. Someone once posted that if the tank contracts and you don't force it to expand that it may not stretch out again to take the full tankfull even in the summer. I'm not sure if that's true though.
  8. Randall Rash
    Randall Rash Member
    149
    25
    Rockwall, TX
    Just my last tank got to 204 miles before the first pip went, then I proceeded to get my best tank in 4000 miles on the Odometer with 551 miles (52mpg) with temps in North Texas anywhere from 40-70. I typically have over 100 miles before losing the first pip.
