Prius Prime tow hook 51961-47010
Discussion in 'Prime Main Forum (2017-2022)' started by dpframing, Jul 26, 2023.
  1. dpframing
    dpframing "Nobody tells me what to do, not even me."
    78
    Chester NY 10918
    2022 Prius Prime
    Here's a good one for Prime experts. Does anyone know the specs for the 2022 Prius Prime tow hook? i. e. metric thread size etc?
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    779
    308
    Maine
    no idea. sorry. I do know that my 2011 gen3 has a completely different bolt diameter and threads from my 2017 plugin. They are not compatible parts. I have used these on both cars, multiple times.
  3. dpframing
    78
    Chester NY 10918
    2022 Prius Prime
    I'll try posting this again in this forum. I am carrying a fishing boat on the roof with a rack and I need 4 towing eyelets to rope down the forward and aft. I don't want to use the Toyota eyelets since they stick out too far from the bumpers. I am trying to match them to regular bolts. Does anyone know the bolt and thread size of the OEM towing eyelets for a 2022 Prime? It's not in the manual- it's not on this site. There must be a set of numbers like "20mm x 100mm" out there in the universe written down on paper somewhere. I can't travel to Japan to ask a tech rep in person. So any info here would help.
  4. Tideland Prius
    16,609
    *threads merged*
  5. sylvaing
    sylvaing Senior Member
    1,210
    514
    Try bringing the tow hook to a fasteners store. They'll probably be able to tell you that info for you and have the bolt you want.
  6. dpframing
    78
    Chester NY 10918
    2022 Prius Prime
    It's an M20. But the thread pitch is 3 not 2.5 . Doesn't exist -that why Toyota makes them that size.
  7. sylvaing
    1,210
    514
    ... Unless you know someone that has access to a metal lathe
  8. dpframing
    78
    Chester NY 10918
    2022 Prius Prime
    It's an M20 diameter with a pitch of British #8 thread size. Does not exist. But if I could find someone who has a tap bit that can cut a #8 thread into a M20 blank bolt, I got it.
  9. Mendel Leisk
    41,850
    Even though the price of the tow lugs is not trivial, I’d guess it’d be cheaper than machining-from-scratch, to just buy four of them, cut them shorter and weld on something like a chain link?
    Or just live with the excessive projection?
    dpframing likes this.
  10. Trollbait
    12,662
    Or just check the nearby scrap yard.
    sylvaing likes this.
