roof interior light in back seat won't turn off
Discussion in 'Gen 5 Prius Main Forum' started by Hannah Andersen, Jul 28, 2023.
  1. Hannah Andersen
    Hannah Andersen Junior Member
    Dallas/Ft. Worth
    2022 Prius
    2023 Prius Generation 5
    The light in the back seat won't turn off. I have no idea what I pushed to turn it off. Will it drain my battery if I don't figure it out?
  2. hill
    8,920
    Check the little switches that turn the light on for the back door. One or the other may just simply be stuck.
    No, it won't run your battery down because as of about 5 years ago virtually all cars have technology that turns the lights out when people don't close the doors or in your case perhaps a stuck switch.
  3. Tideland Prius
    16,617
    It's a small enough light that it shouldn't.
    But is it both lights or just one? Perhaps you turned on the reading lights by accident. If so, press the left or right button to turn off. The centre button turns on/off both rear lights.
  4. ChapmanF
    18,545
    In my Gen 3, I think there's also a switch on the second dome light itself. Does Gen 5 have that too? Make sure that's not set for always-on.
  5. bisco
    52,390
    it wouldn't surprise me if it's something in the menu like so many cars these days, but idk.
  6. hill
    8,920
    Two odd things. One is that she says just a rear light. Two, she never said one way or the other if she figured it out.
    Tideland Prius likes this.
  7. SupersonicPrius
    SupersonicPrius Junior Member
    39
    55
    Colorado
    2023 Prius
    Up front the light is a haptic touch but in back the switches are physical buttons. I’d press them to see if that fixes it.
  8. Uhcoustic
    Uhcoustic Member
    55
    30
    2023 Prius Prime
    XSE
    Any chance this is the proximity interior lighting that turns on when you stand near the car with the key fob? If you back maybe 10 feet away and wait a moment, does it fade away on its own?
  9. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    I just got home from the dealer with my brand new XSE prime and had the same damn thing happen in my driveway. Drove me nuts! A Google search later brought me right to this thread.
    The rear seat overhead lights would not go off. I never even turned them on!!
    Anyway, short story long it was some combination of the haptic door button on the front dome, light or the one right next to it. I tried pushing the buttons of the lights that were on, and that did nothing no matter what position they were in. Very odd. Oh well, it’s taken care of now and I got her plugged in for the night for the first charge at home ever.
  10. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    Look in the owner's manual under 'Interior Lights' to see what is supposed to happen.
    In summary one of the switches for the front light is a master switch. If that is on, all the lights stay on. Once that is turned off, the individual switches for each of the lights work. Of course, if the master switch is under door control, you won't be able to deal with the individual rear light switches until you close the doors and wait until the front lights turn off, indicating that the master switch has turned off.
  11. boardhead
    boardhead New Member
    2026 Prius Plug-in
    SE
    I just received my brand new 2026 Prius Prime SE today, and I had this exact problem. The front interior light control was set to turn on with the door (green light on), but no matter the position of the rear interior light switches, they didn't turn off after all doors were closed, while the front lights turned off after 15 seconds. The issue was resolved by playing with the switches for the front interior lights. In the end, the front controls were all reset to their state before I started playing, but the rear lights functioned as expected (ie. turned off with the front lights after 15 seconds). My guess is that there is a bug in the logic for the interior light controller, and it got into a state that was somehow reset by playing with the controls. I don't know how it got into this state, but I'll report back here if I ever figure it out.
