My prime doesn't have much power when not in the EV mode
Discussion in 'Prime Main Forum (2017-2022)' started by Ngan Sao, Jul 29, 2023.
  1. Ngan Sao
    Ngan Sao New Member
    Sacramento, CA
    I have 2021 Prime. Recently I see the car doesn't have much power when it is in gas mode. (0% electric in the battery). It slowly accelerates from 65 mph to 75 mph or more. If in the EV mode, the car runs perfectly. Took it to the dealer 2 times, they explained that the Prime is different with the Prius. The Prius still has the electric on battery charged from the engine while the Prime has no electric at all when the electric runs out. The engine of the Prime is too small, so it doesn't have much power on the high speed. The dealer said nothing wrong with the car. They advised that If I don't like the way right now, sell it and buy a Prius. If you have a Prime, please tell me that you have the same problem or not. I really doubt about the dealer's theory. TIA.
  2. Tideland Prius
    16,553
    It just feels that way because gasoline engines need to rev up to get max torque. EVs have max torque the moment you accelerate so the Prime feels faster in EV mode but it actually isn’t if you take a stopwatch.
    PriusCamper and jerrymildred like this.
  3. fuzzy1
    10,431
    I'm skeptical of this dealer explanation. The Prime should have the same engine and engine power as the non-Prime, though the car itself is a bit heavier.
    The Prime should also have a small portion of its battery reserved for HV operation just like the non-Prime. But even the non-Prime can run its battery out and feel sluggish until it gets some recharge. Could you have run into this equivalent situation?
    jerrymildred likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,149
    Tampa, FL
    Your dealer is highly confused. Both cars have the same engine other than the sprague clutch in the Prime that allows faster EV speeds without over revving the electric motors. And, no, just because you have run out of EV range does NOT mean there is no juice available in the battery. It's simply running just like any other Prius.
    As Tideland correctly pointed out, it just feels a little sluggish in HV mode because MG2 isn't providing as much instant torque as it does in EV mode.
    Ngan Sao likes this.
  5. sylvaing
    sylvaing Senior Member
    1,210
    514
    Sprague clutch sound very similar to a bike freehub.
  6. ForestBeekeeper
    ForestBeekeeper Active Member
    772
    304
    Maine
    Try this, When you are driving it using the ICE, put your vehicle into 'PWR' mode and see if it handles differently. Compare that to 'ECO' mode.
    In my 2017 prime the handling with 'PWR' as compared to 'ECO' is remarkably different.
    Mash the accelerator to the floorboard in each mode and see if it accelerates differently.
    Some posters will want to argue that this is impossible. Try it, and tell us what you find.
    In my area, some roads are very hilly. My wife complained that she was barely able to top some of the hills. But when we put it in 'PWR' mode and set cruise control, it takes the hills at 65mph with no slowing.
  7. bisco
    51,892
    is this behavior new, or is the car new to you? it sounds normal, as stated above.
  8. sylvaing
    1,210
    514
    I have a 2017 Prime that is new to me from three weeks ago. Took it this weekend for a round trip Ottawa Toronto. Even with the battery at "0%", there is still batterie charge left in the pack for helping the engine when accelerating in Hybrid mode. I had no trouble passing cars on the two way roads I took. Mind you, it's not comparable to my Model 3 where I have to monitor my speed not to overspeed (too much) but I was never affraid of running out of time to pass.
    If you have a OBD2 adapter, try pairing it to Hybrid Assistant (Android app) to see what's going on with the motors, engine and battery.
  9. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Ngan, the service writer you spoke with doesn't know what they're talking about. They are a commission salesman for service, not a well trained technical expert.
    Do try the accelerator pedal mode in PWR. It makes a difference. It determines how much motor or engine output you get for a given amount of push of your right foot. We have to remember here that Toyota's wisdom gave us two completely different things called "Mode." The propulsion modes are EV, EV Auto, and HV. The accelerator pedal modes are ECO, Normal, and PWR. (We use Normal around town and PWR on the freeway for more giddy-up.)
    SPRAG clutch, a one-way clutch, although overrunning clutch might be a more accurate description in this usage.
    Sprag Clutch, Overrunning Clutch, Holdbacks, Backstops | Formsprag Clutch
  10. BiomedO1
    3,558
    1,846
    SacTown, Ca
    Welcome..
    Your power-train warranty is 5 years 60K miles; so if there is something wrong - it's covered. If you don't believe your dealer; take it to another one; you have a few to chose from in the Sacramento region. Doesn't hurt to get a second opinion; especially since your description from your current dealer; had some factual errors in them. It may have been a simple misunderstanding.
    If there isn't anything wrong, try running the car in 'normal' or 'power' mode; that should get you the performance you want - but a small ding to your gas mileage ( as stated in post #6). It still won't perform as well as EV mode; but it'll get you close.
    Whenever I jump onto the highway; I manually switch to HV - reserve EV mode for city streets, stop & go traffic. The car handles much better in EV; during those situations. Normal- or Power- mode while traveling in the Sierras; otherwise you'll really have to mash that accelerate peddle - It's just how this car works....
    Hope this helps
  11. jerrymildred
    11,517
    14,149
    Tampa, FL
    Similar idea but there's more to it. Watch the whole video for a brief explanation of your transaxle, but here's the point where Professor Kelly talks about the sprague clutch.
    MitchA likes this.
  12. bisco
    51,892
    If there aren’t any codes, no dealer will do anything
  13. Ngan Sao
    Ngan Sao New Member
    Sacramento, CA
    Thank you for all your advices. My wife had the car from brand new for 2.5 years and she took the car to the dealer the first time. When I drove it, I felt the same problem and just took the car to the dealer the 2nd time. I just tried the Normal mode as ForestBeekeeper said, and it helped a lot. I realized that the car automatically switched from EV mode to Eco mode. That's why the car had much less power. To go to 2nd dealer, they would charge 75$ for the inspection while the first dealer didn't charge because I bought the car from them. That's why I need the advices from the forum first. Next step, I will borrow a normal Prius to run to see how different with my car. Thanks.
  14. jerrymildred
    11,517
    14,149
    Tampa, FL
    That's a little like switching from dark to dry. The two settings have nothing to do with each other. While in EV mode, the car can be running in ECO, Normal, or PWR. And all three settings are available in HV mode as well. See post #9 quoted below. It can switch automatically from EV to HV.
    I suggest spending some time in the owner's manual. It's one of your best friends if you own a Prius Prime.
    Tideland Prius likes this.
  15. jerrymildred
    11,517
    14,149
    Tampa, FL
    One more thing on the difference in feel. Because of the sprague clutch, MG1 can help MG2 power the car. That gives it a little more torque.
    Tideland Prius and Ngan Sao like this.
  16. Mendel Leisk
    41,397
    They’re likely right. I’ve read this here before; the Prius Prime has the same engine; there might be slight differences in the transaxle, that’s it. The Prius Prime is heavier, that’s a factor.
    Owners have reported here it’s a little sluggish in hybrid mode. But that’s normal. the dealership can’t help with that, and their advice is sound.
  17. sylvaing
    1,210
    514
    You're right, there is a difference in the final gear ratio between the Prius and the Prime. Posted above but set to a different time offset which explains it:
  18. bisco
    51,892
    even my pip is more sluggish in hv mode, that's the nature of electric motor instant torque
  19. Zed Ruhlen
    Zed Ruhlen Active Member
    247
    138
    Hood River, OR
    2018 Prius Prime
    The Prime is definitely more sluggish in HV mode than EV mode. This is due to that Sprague clutch and the nature of the planetary gear set. In EV mode the car has more torque due to the two electric motors working together but in HV mode the engine torque is split between MG1 and MG2 (If memory serves at a 30/70 ratio). The upshot is that in HV mode the car has less torque than in EV mode. In my 2018 the only real effect of PWR mode is that the dash turns red and the engine is louder. Ok, so there's a bit more power but it isn't that dramatic.
  20. PT Guy
    1,085
    711
    Please explain. In EV mode the motors are, of course, powering the drive. In HV mode the engine, and sometimes a motor, is powering the drive. The engine power (not just torque) goes through the planetary transmission to drive the car. What does it mean, "...in HV mode the engine torque is split between MG1 and MG2...."
    Power gets work done. Power is force over a distance. Torque is merely a twisting force. (As an example, all the industrial power sources I've seen list the prime mover's output...diesel or turbine...in horsepower or kilowatts, and the torque is never listed--nobody cares. Kilowatts are used even for mechanical power because it is a universal measure worldwide; horsepower units vary depending on the usage and region of the world, e.g. shaft horsepower is different from brake horsepower for the same usage. Imperial hp = 745.7 watts; metric hp = 735.5 watts.) (An electric motor with a locked rotor produces zero work but infinite torque...until the motor goes up in a blue flash and cloud of black smoke.)
    Here's a spec from a medium speed MAN diesel engine...V-14, 21,500 hp (expressed as kW) @ 500 rpm, no mention of torque.
