Rubber mats & battery vent
Discussion in 'Gen 5 Prius Main Forum' started by Gwyd, Aug 1, 2023.
  1. Gwyd
    Gwyd Member
    113
    78
    NE Florida
    2023 Prius
    I noticed the other day that the rubber mat installed by the dealer partially covers the vent underneath the passenger side rear seat.
    I'm assuming this is the vent to cool the hybrid battery and I'm considering cutting the mat so it doesn't block the airflow at all. I'd rather not take the mat out completely - it's easier to clean out the beach sand with them.
    Thoughts?
    51,840
    First I’d ask the dealer, then I’d cut it.
    sounds like the wrong mat
    daisy555 likes this.
  3. Preebee
    Preebee Senior Member
    867
    771
    Midwest
    2023 Prius
    How is that possible? The vent is well off the floor. Pics?
  4. Gwyd
    Gwyd Member
    113
    78
    NE Florida
    2023 Prius
    Pic attached. I adjusted the mat a little bit (he'd installed it crooked) and now it comes up to the first row of the vent. So it's really only one row of the seven rows that's blocked. Still not great in my opinion, but not as critical as it seemed looking down at it.
    My mat is stamped PT908-47230 if anyone wants to compare.
    tovli likes this.
  5. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    The battery intake vent is on the driver's side of the rear seats (not the passenger's)
    and is elevated from the floor. See page 77 of the owner's manual and maintenance (cleaning and filter replacement) starting on page 441. I've attached a pdf and a picture of the vent from my car.
    I don't know what the passenger side is for. As far as I can see, the manual does not reference it. In my car, the mat comes up to its bottom.
    Gwyd and tovli like this.
  6. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    I wonder which vent this is. I wonder if the Prius and Prime have the vent in the same place?
  7. Hammersmith
    Hammersmith Senior Member
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I'm not 100% certain, but I believe the vent on the passenger side is the cooling output. The driver side vent is absolutely the cooling intake. It takes the air in and runs it under the battery. I suspect after the air goes under the battery, it comes out of that passenger side vent.
    tovli likes this.
  8. bisco
    51,840
    would you want that in summer? they used to exit under the hatch corner, where the mice come in :p
  9. Gwyd
    Gwyd Member
    113
    78
    NE Florida
    2023 Prius
    @aforkosh Thanks for the info and pdf link - good catch. I won't worry about it then. Curious to know what the other venting is for if anyone knows. Could it be to cool the 12v battery?
    Good to know that I need to clean the filter, and nice of them to put it somewhere accessible. I only cleaned the battery cooling fan once on my '05 because it was such a pain to get to. Since I didn't carry animals around and was usually the only one using the car, there wasn't anything to clean so it really felt a like a huge waste of time & effort.
    @bisco I wonder if the passenger seat cooling fans pull in that air. Kinda defeats the purpose of a butt cooler if it's sucking in hot air!
  10. purplePriii
    purplePriii Active Member
    275
    122
    Wait, you guys have vents in the back for the battery on the 2023? I have a Prime and I didn't see any vents in the back
  11. Preebee
    867
    771
    Midwest
    2023 Prius
    They're on the lower-front of the back seats. Non-primes just have one on the driver's side. Never block your vents!
    My all-weather mat is well below my battery vent btw.
  12. Hammersmith
    2,302
    2,316
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The Prime doesn't have a vent. The main traction battery on the HEV Prius is cooled by air from the cabin pulled from under the rear seats. The larger battery on the Prime is mounted underneath the car and requires much more cooling, so it's got its own liquid cooling system that runs from the engine compartment. I believe it's also capable of warming the battery up before use(driving or charging), but I don't know if that heat is generated from the engine, heat pump, or something else.
    purplePriii likes this.
  13. daisy555
    1,715
    708
    CT
    I’m afraid to ask where these vents are on a 2009. I know about the vent on the seat. Did a quick check and couldn’t find anything along the base of seats.
  14. bisco
    51,840
    that's the only one on gen 2
  15. daisy555
    1,715
    708
    CT
    Thanks!
    #15 daisy555, Aug 3, 2023
