In Case Of Emergency - Break Glass?
Discussion in 'Gen 5 Prius Main Forum' started by tovli, Jul 31, 2023.
  1. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    351
    272
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    For 14 years I drove with a giant "emergency hammer" in my prior Prius. Luckily I never needed to use the thing. When moving into my new 2023 Prius Prime XSE, I naturally installed the thing hoping I would never need it.
    Reading the owners manual made me question if the thing would actually work on the new car:
    Of course there is that "Laminated Glass(2 If equipped) is used in the windshield and windows of this vehicle" and "Laminated glass cannot be shattered by an emergency hammer", but "contact your Toyota dealer for further information about an emergency hammer" that won't work?
    So on my 2023 Prius Prime XSE, the windshield is indeed laminated. The side and rear window are "Tempersafe" not "Lamisafe" so I am going to assume the hammer will shatter the side window, but the window tint sheet will probably hold the pieces in place...
    Then again this article suggests the spring loaded devices were more effective than the honkin' hammer variety I've been packin'.
    #1 tovli, Jul 31, 2023
  2. TGTGUUD
    TGTGUUD Member
    91
    70
    San Francisco
    2024 Prius
    I’d be surprised if a Prius has laminated side glass windows.
    Yes a spring-loaded device can break non-laminated glass easily and discretely. I know this for a fact living in the SF Bay Area.
    tovli likes this.
  3. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    The non-Prime owners manual says the windows, except for the windshield, are tempered glass. I've attached the relevant page from the owner's manual.
    tovli likes this.
  4. Hammersmith
    Hammersmith Senior Member
    2,300
    2,313
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I just checked. My Limited AWD has laminated front windows and windshield.
    SM-S901U ?
    tovli likes this.
  5. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    Do you think the XLE and Limited have the same glass components? I guess I can read thru the manual at done point.
  6. Hammersmith
    2,300
    2,313
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    They do not. Strangely enough, all three trims levels have different front door glass. The LE also has a different windshield than every other trim including the SE. All rear door glasses and the hatch glass are the same.
    I don't know what the differences are between the front door glasses. I suspect the difference in the LE windshield is just the size and shape of the black section around the rear view mirror.
  7. daisy555
    1,715
    708
    CT
    Thanks. The windshield is one of my worries brought on by the person who came on the test drive with me. : }
  8. aforkosh
    413
    272
    Oakland, CA
    2023 Prius
    I'm not sure what that ID refers to. The owner's manual that I quoted from was OM_OM47E41U_(U).
  9. vvillovv
    vvillovv Senior Member
    4,321
    1,509
    NY
    I think it's a hardware guessing game automatically added to the post and it looks like the app doesn't know exactly what it's looking at.
  10. Hammersmith
    2,300
    2,313
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Normally I post from my laptop. Occasionally I post from my phone with Tapatalk which tries to label the device being used. SM-S901U is the product code for a Samsung S22. I use Tapatalk to post so rarely that I haven't bothered to figure out how to turn it off. It used to say " <phone model>", but I guess that's broken now.
    edit: Ahh, the confusion is this board's fault. For some reason, it edits out certain word combinations and replaces them with a ?. My sentence above was supposed to say "S e n t from <phone model>", but the board software changed it on its own.
    #10 Hammersmith, Aug 2, 2023
    vvillovv likes this.
  11. aforkosh
    413
    272
    Oakland, CA
    2023 Prius
    "The map is not the territory"
    "Trust, but Verify"
    I checked the windows of my Limited this morning. The windshield and large front side windows are labeled 'Lamisafe', whilte the small front side windows (in front of the mirrors) and main rear side windows are labled 'Temperlite'. The samll rear windows have no brand id but have 'Nippon Safety UV ' symbol that does not appear on the other windows. The hatch window is labeled Therlite and has the Nippon Safety UV' designator. I assume the embedded heater lines make this a speacial case.
    So, the manual is wrong for the Limited trim version.
  12. vvillovv
    4,321
    1,509
    NY
    The manual I got with our 2017 Prime lists all available options for all 3 2017 Prime trims. It was more than a bit confusing in the betginning trying to understand which options our Prime Plus came with and which options belonged to other 2017 trims.
    I'd think the manuals are probably less confusing to owner of the higher trim levels, but than again ....
    Tideland Prius likes this.
