12V battery at 11.6 V and sometimes the prius does not start?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wirelessjava, Aug 3, 2023.
  1. wirelessjava
    wirelessjava Member
    104
    Union City, CA
    I have tested my 12 V battery ( this is the battery bought from AAA) currently it is 11.6 V when it should be 12.6 V. Has anyone had this problem where my gen 2 prius sometimes does not start up because of the low volts on the 12 V battery ?
    ====wire
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Still only driving 2 miles per day?
    bisco and wirelessjava like this.
  3. wirelessjava
    wirelessjava Member
    104
    Union City, CA
    Yes that is right.... I am going to guy the Toyota OEM battery and be done with this.
    Thanks for remembering.
    SFO likes this.
  4. Tombukt2
    13,336
    2,401
    I don't think a Toyota branded 12 volt is going to make a huge big difference the kind of 12 volt you buy might make a difference like glass mat versus flooded liquid etc. But you never know the Toyota dealer may be having a sale and you might do okay I do fine with the $193 battery from Walmart what are we 51R I think or something like that never have any problem with them till they die but I drive the car so that's every 3 to 7 years depending upon whatever it is everything depends on and then one of the cars we have one of these universal batteries what kind you put in alarms and whatnot. Works just great. The 12 volt and the Prius doesn't really do anything power up the computers the lights everything in my car is LED so not a lot happening I guess.
  5. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Just get a charger and use it
  6. bisco
    52,334
    i got a noco for when we're in florida, 25 bucks. my 4 year old oem is still 12.75v
    JohnPrius3005 and wirelessjava like this.
  7. wirelessjava
    wirelessjava Member
    104
    Union City, CA
    Tell me in the future when it does fail. I say it fails at 7 or 8 years
  8. bisco
    52,334
    my original lasted 7 years, and i had never put it on a charger while in florida for 2 months every winter. a good battery, no doubt.
    wirelessjava likes this.
  9. wirelessjava
    wirelessjava Member
    104
    Union City, CA
  10. Mendel Leisk
    41,849
    @wirelessjava do you garage park, have easy access to 120 volt outlet?
  11. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    You are not driving enough to keep the 12 V battery fully charged. Buy a automatic multi-stage battery charger and use it regularly.
    I've been regularly charging my new in 2016 12 V and it is still holds 12.8-12.9 V (after surface charge bleeds off). That's coming up for 7 years in Sept.
    [EDIT]
    I should add, the battery I replaced was the OEM original from the factory battery. So that one lasted ~10 years.
    #11 dolj, Aug 5, 2023
    JohnPrius3005 and Mendel Leisk like this.
