What hybrid replacement wires to buy?
Discussion in 'Gen 2 Prius Main Forum' started by Patio, Jul 31, 2023.
  1. Patio
    Patio New Member
    Tallahassee, FL
    SE
    I'm hoping for advice on what hybrid battery cables to replace on my 2008 Prius after I noticed that the bus bars were corroded. The cables on each side of the battery have corrosion that extends from the connector to underneath the cable sheath. It's been difficult to find the correct new ones
    One of the cables I want to replace is marked G9240-47020A, but I can't find it new. Perhaps it's been replaced by a newer model? Here's a list of parts I've found but because there are no pictures I'm not sure what to buy.
    Wire, Frame, No. 2
    Product ID: 82165-47040
    Hybrid Battery Wire Harness
    G3830-52010A
    (can only find on eBay, used, but the picture looks exactly like the one I want to replace)
    Plug Assembly Electric
    Product ID: G3830-47061
    Product ID: G3830-33011
    Product ID: G3830-47050
    Product ID: G3830-42031
    Cable Main Battery
    Part Number G9242-47090
    Any advice is much appreciated.
  2. Patio
    Patio New Member
    Tallahassee, FL
    SE
    Now that I'm able to post links and photos, this wire harness in particular is what I'm hoping to buy new:
    G3830-52010A
    I can only find it used on ebay. Where can I obtain it in new condition?
  3. alftoy
    alftoy Senior Member
    1,132
    509
    Saskatchewan, Canada
    Order it from your local toyota dealer. Try part number G3830-47050
  4. Patio
    Patio New Member
    Tallahassee, FL
    SE
    Ok thank you! I found it
  5. Patio
    Patio New Member
    Tallahassee, FL
    SE
    How about the G9240-47020A? I can't find it in new condition online, either.
  6. alftoy
    1,132
    509
